Voltage fluctuations causing aftermarket DashCam to restart?
Discussion in '3rd Gen Tundras (2022+)' started by Fillabuster, Apr 26, 2024.
  1. Apr 26, 2024 at 10:41 AM
    Fillabuster
    Fillabuster [OP] New Member
    South Pasadena
    2023 Lunar Rock Tundra TRD OR Limited
    Go Rhino E1 Running Boards, GFC Topper
    I have a 2023 Tundra Limited (non-hybrid) and a Vantrue N4 that is tapped into the OEM camera 5-pin under the headliner. Because the N4 uses a capacitor vs a battery, it seems very sensitive to voltage changes and will restart when my voltage dips below 12v. Up until I installed this camera, I didn’t realize how often and how much lower than 12v my voltage meter would read (I assumed it would dip during auto stop/start, but it seems to fluctuate while driving as well).
    Anyone else notice this and/or have a solve for maintaining a more consistent voltage from the 5-pin?
    Thanks in advance.
  2. Apr 26, 2024 at 11:41 AM
    raylo
    raylo not so new member
    Frederick, MD
    Same happened with my Viofo cam using the headliner tap but mine only rebooted upon auto restarts. I swapped mine over to switched and unswitched hardwires from the passenger side fuse box (behind the glove box) using fuse taps. This was very easy.
  3. Apr 26, 2024 at 12:26 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    No issues using my rexing cam via oem cam harness.
    Fillabuster[OP] likes this.
  4. Apr 26, 2024 at 12:27 PM
    Fillabuster
    South Pasadena
    Thanks for the reply. Did that on my 2007 Tacoma. Trying to avoid running cables down the A pillar (I assume there are side curtain airbags in that area).
  5. Apr 26, 2024 at 12:29 PM
    Fillabuster
    South Pasadena
    Looks like the Rexing Cam has an internal battery… might have to switch cams or run cable to the fuse box…
  6. Apr 26, 2024 at 12:35 PM
    eddiefromcali
    Eddie
    100% Stock
    Tundrastruck91 likes this.
  7. Apr 26, 2024 at 1:34 PM
    raylo
    Frederick, MD
    A-pillar covers are trivial to remove and replace.
