Voltage Bouncing all over the place
Discussion in '2nd Gen Tundras (2007-2013)' started by SkipperPete, May 4, 2021.
  1. May 4, 2021 at 3:20 AM
    SkipperPete
    SkipperPete [OP] New Member
    Pete
    Nicholasville, KY
    2012 Silver Tundra Crewmax
    Hey fellers,
    My voltage is constantly bouncing all around. It never reaches the mid-mark, always below... Even while throttling up or driving. It's also never steady. It's always fluctuating back and forth. My head unit is reading it anywhere between 12.7 - 13.2. I read through some posts and found most people float between 13.0 - 13.5. Here are some other symptoms that I've noticed. Whenever the headlights are on and I do anything else (tap the brakes, use blinker, turn on interior light) the headlights will dim for a split second. But even as I sit with my foot on the brake, I can see the headlights kinda flickering from bright to dim every couple seconds. I've also recently noticed my interior lights will flicker slightly, as well as the light behind the odometer. This is driving me nuts! The previous owner had a whole sound system put in with a powered sub and an amplifier under the seat. This all seems to be professionally installed.
    Should I be concerned? I'm not sure if it's the alternator or a battery or what. I've never had any other relatable issues! Thanks for any help!
    Pete
  2. May 4, 2021 at 3:26 AM
    timsp8
    NY
    You can go to just about any auto parts store to get you battery checked. I’d start with that since it’s free.
    SkipperPete[OP] likes this.
  3. May 4, 2021 at 4:51 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    If it happens while running it is much more likely to be the alternator than the battery. It could also be cause by loose connections or something grounding out. Of those, I would hope for a bad alternator. Much easier to diagnose and repair.
  4. May 4, 2021 at 10:13 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    You could very easily just have a loose battery cable. Always start with what's free to check.
    SkipperPete[OP] and Bakershack like this.
  5. May 5, 2021 at 4:34 AM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    The voltage on my '07, measured at the ECU through the OBD port, runs from 13.5 up to 13.8 or so after the initial start up.
