Vleds reverse lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by Alex261, Jan 9, 2021.
  1. Jan 9, 2021 at 7:39 AM
    Alex261
    Alex261 [OP] New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    Do these work a lot better than stock? I purchased LED bulbs from Autozone and I felt the stock bulbs did a better job. The autozone bulbs seemed to wash out my back up camera a little bit and didn’t seem like they lit up more area. The vleds bulbs on the website seem like they have more led lights than the ones I purchased. Just curious if any one has them and really likes them
  2. Jan 9, 2021 at 7:45 AM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    6 inch Pro Comp lift. OME rear springs with Coach Builder +3 shackles. Coach Builder tie rod ends. ICON 2.5 front and rear shocks with remote res. ICON Hyd bump stops. 35" Nitto Trail Grapplers on 18" fuel rims. Kenwood DNX 892 head unit with JL audio and RF amp pushing 2 Image Dynamics idq10 subs. SABM, S POD switches for 42" in bumper and 32" behind grille LED light bars. Full interior and exterior LED conversion. LED flush mount back up lights in rear bumper. Valentine one radar detector. V Leds under dash and seats foot well lighting. TRD pro head lights and grille. Full AJT dash kit
    I use them both front and rear, also use the one above license plate (mine is in red for extra brake light) and they are very bright.
    https://www.vleds.com/shop-products/lp-series/lp-reverse-72-w-5500k.html
  3. Jan 9, 2021 at 7:46 AM
    Failure2comply
    Failure2comply Master HVAC Tech
    VA
    2008 Tundra Crewmax Limited w/factory 20" wheels
    Trailer brake. Limousine tint in rear windows. Ultra Gauge "Blue". Toyota bed mat and bug deflector.
  4. Jan 9, 2021 at 7:57 AM
    Vleds are the way to go for leds. You get what you pay for.
    Juanjoolio007 and TXTundra2722 like this.
  5. Jan 9, 2021 at 8:05 AM
    clarkritchie
    clarkritchie New Member
    I recently fell hook, line, and sinker for a targeted ad after complaining to a friend about the awful, horrible, embarrassingly poor OEM reverse lights. These are Diesel LEDs, which are more than likely a grossly overpriced version of the same thing (bulb only, no heatsink) that you can find on Amazon for way, way less. (My gullibility here is not the point!) I also have a cargo light from HID Kit Pros.
    Anyhow, this was backing up last night.
  6. Jan 11, 2021 at 6:38 AM
    nodak67
    nodak67 New Member
    JR
    just a note, if you use vleds (which i do for my 4runner and tundra), the reverse lights will over power your reverse cam. you will need to compensate for the added brightness in the menu.
    only downside is that you may lose some fidelity in the camera sharpness of seeing objects.
    Iceman89 likes this.
  7. Jan 29, 2021 at 7:15 PM
    hainesfive
    hainesfive New Member
    MD
    2020 Black TRD Sport Crewmax
    TRD Dual Exhaust Weathertech rear floor liner Black out badging Linex sprayed bed TRD PRO Wheels VLED Interior and exterior Drivers side grab handle Front drivers and passenger window tint Focal speaker upgrade with amp and 10" sub Retrax pro bed cover Falken tires
    I have VLED interior and exterior not cheap but well worth the $$$
    Tundra234 likes this.
