VLED Switchbacks and OEM LED Headlights
Discussion in 'Lighting' started by Tundyfundy, Oct 18, 2019.
  1. Oct 18, 2019 at 1:30 AM
    Tundyfundy
    Tundyfundy [OP] Petunia The Tundra, and her sidekick Colbie
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I just purchased the OEM LED headlights! I love my current VLED switchbacks so much. Such a good product. Is it possible to add VLED switch backs to the LED headlights? Anybody running this setup?
    DISCLAIMER: I am going to be running the iHacker harness as my truck is a 2016 that came with Halogen lights all around.
  2. Oct 18, 2019 at 7:31 AM
    iHacker
    iHacker SW TRD PRO
    Mario
    AR
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    You can use switchbacks, just forget about depin/cut gray wire under dash and you should be good, just have in mind this due to different turn signal bulbs the switchbacks only work in DRL mode then when headlight is activated and DRL turned off the switchbacks would be turned off. You cannot modify this because fuses will start popping up.
  3. Oct 18, 2019 at 7:43 AM
    iHacker
    iHacker SW TRD PRO
    Mario
    AR
    You have to do something like this instead of depinning that gray wire
  4. Oct 18, 2019 at 7:51 AM
    Tundyfundy
    Bay Area, CA
    Thank you!! Exactly what I needed!
  5. Oct 18, 2019 at 9:27 AM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Just a heads-up. The DRL/Amber turn signal socket from the halogen headlights are different from the LED headlights. If you're planning to move your VLED switchbacks from your halogen headlamps to the LED headlights, they will not fit.
    Here's a response from iHacker when I tried to fit my switchbacks to the LED headlights:
    You can’t use your current LED turn signal bulb in the new housings they are completely different bulb - old trucks use a 3157CK bulb and the new headlights use a smaller 7444NA.
    Tundyfundy[OP] likes this.
  6. Oct 18, 2019 at 9:34 AM
    iHacker
    iHacker SW TRD PRO
    Mario
    AR
    If you have the VLED turn signal from old halogen headlights they should work but you have to repin the turn signal adapter to make them work correctly, if you are starting fresh with new VLED bulbs make sure your get the 7443 bulbs
  7. Oct 18, 2019 at 10:01 AM
    Tundyfundy
    Bay Area, CA
    Thank guys. Exactly what I needed. I’m going to start new with fresh bulbs and sell the old ones I think.
  8. Oct 18, 2019 at 11:31 AM
    Shephard_Of_The_Tundra
    Shephard_Of_The_Tundra DIY try guy
    Corpus Christi, TX
    2016 Black Tundra SR5 4.6 DC 2WD
    Morimoto 2 stroke H4 LED Headlight Bulb VLEDs 3157ck Amber Triton V6 TurnSignal Auxito LED reverse bulbs OEM Toyota LED smoked fog lights Auxito LED T10 license plate bulbs Auxito LED T10 Side marker headlights LASFIT LED T10 3rd brake light Xenon Depot T10 LED Bed/Brake Lights TRD Off-Road Black/Chrome Wheels Bridgestone Duellers 255/70/R18 Front & Rear TRD Sway bars MBRP Dual side exhaust exits Drop-in K&N air filter TRD air flow accelerator Toyota Rubber floor liners OEM Rear under seat storage box Kenwood DMX7706S head unit TRD Shifter knob Center console organizer tray Dual USB fast chargers center stack
    To eliminate the triton from keeping amber on even when the headlights are on, I cut the purple wire going to the turn signals. It controls the dim for the turn signals. It will still work during the drl function but turn off when headlights come on
    iHacker likes this.
  9. Oct 18, 2019 at 11:35 AM
    Tundyfundy
    Bay Area, CA
    So are you sating once you turn on the headlights the switch backs run amber?
  10. Oct 18, 2019 at 11:54 AM
    Corpus Christi, TX
    My bad, I just have the regular Triton's. No switchbacks
  11. Oct 18, 2019 at 11:55 AM
    iHacker
    iHacker SW TRD PRO
    Mario
    AR
    Same as I mentioned before, if you go with my harness and leave the Amber DRL untouched (leave gray wire in place and tap instead of depin/cut) you go to have the switchbacks functionality but this would be turned off when you turn your headlights ON.
    This is because some differences in the pinning between the old bulb 3157A and the new 7444NA
