Violent shaking
Discussion in '2nd Gen Tundras (2007-2013)' started by DJB4x4, Apr 9, 2023.
  1. Apr 9, 2023 at 7:06 AM
    DJB4x4
    DJB4x4 [OP] New Member
    My 2013, 5.7 Liter Tundra violently shakes and feels like the trans is slipping, only when I floor it, while cruising at 70 mph. I did some research and wonder if it could be a sensor on the transmission?
    My truck has about 150,000 miles on it, and is all factory.
    I have intermittent dash lights that come on, (4Lo-flashing, check engine, Trac Off)
    Recently had my mechanic do standard maintenance on truck, but lights were not on dash when I dropped it off.
    I imagine these lights need to be on, when plugging in an OB2 scanner?
    Any advise would be helpful,
    Thank you
  2. Apr 9, 2023 at 9:31 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    See if you have any codes. Also check your battery with a load tester. My first gen bucked like a bronco when it misfired and issue was a bad coil.
