(Video) 2014 making weird drivetrain noise
Discussion in '2.5 Gen Tundras (2014-2021)' started by badmotofing3r, Oct 31, 2020.
  1. Oct 31, 2020 at 9:17 PM
    badmotofing3r
    badmotofing3r [OP] To be so civilized, one must tell civil lies
    Zach
    Wyoming
    Hot Tamale
    Toytec lift and the works
    Hello guys,
    I am a proud owner of a 2014 4x4 TRD OFF ROAD for almost 4 years now.
    77k miles
    Recently after having the rear window down for my dog to enjoy the wind, I heard a rather odd noise coming from my pickup.
    It only happens when under load. It also happens if it's in four wheel drive also.
    I have checked the following:
    U-joints - nice and tight & re-greased
    Carrier bearing - looked good, no play
    Rear diff fluid - changed about 25k ago
    fluid looked good and was at proper level
    Wheel bearings - no play in wheels in any direction
    Brakes - checked pads, rotors, dust cover for debri, and calipers - all good
    My friend (also a Tundra owner) sat in the back seat and stuck his head out the big back window to listen. He says it's definitely in the mid to rear part of the truck.
    I am at a loss. It literally sounds like a peckerhead put a zip tie on my drive line.
    I know the video sound isn't great but it's the best I can do. I wish I had a gopro.
    https://youtu.be/OBiJGDpo4z8
  2. Nov 1, 2020 at 6:48 PM
    badmotofing3r
    Zach
    Wyoming
    Hot Tamale
  3. Nov 1, 2020 at 8:31 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Exhaust leak maybe?
  4. Nov 1, 2020 at 8:41 PM
    badmotofing3r
    Zach
    Wyoming
    Hot Tamale
    I wish. But noise only happens under load. I've tried parking and revving to re-create the noise and it doesn't happen.
  5. Nov 1, 2020 at 8:45 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Only when you press the gas or always when moving?
  6. Nov 1, 2020 at 8:57 PM
    badmotofing3r
    Zach
    Wyoming
    Hot Tamale
    Only when you touch the gas and maybe ever so slightly at deceleration.
    But mostly when accelerating from a dead stop.
  7. Nov 1, 2020 at 10:34 PM
    TXTundra2722
    2015 Black Tundra
    Is your truck completely stock? Everything that isn't should be listed in this post to help.
  8. Nov 2, 2020 at 3:35 AM
    badmotofing3r
    Zach
    Wyoming
    Hot Tamale
    Only thing not stock is my bumper, Baxter oil filter adapter and taller tires 275/70r18.
    No lift, no engine mods - nothing
  9. Nov 3, 2020 at 4:06 AM
    badmotofing3r
    Zach
    Wyoming
    Hot Tamale
    Im starting to wonder if it's a bad universal joint. My u joints have no play but with it making sound only under load, and the sound speeds up as I speed up. I'm thinking it's a u joint.
  10. Apr 27, 2021 at 9:18 PM
    badmotofing3r
    Zach
    Wyoming
    Hot Tamale
    Solved. Bad rear u-joint.
    Sumo91 and landphil like this.
