vibration
Discussion in '1st Gen Tundras (2000-2006)' started by greger101, Mar 19, 2021.
  1. Mar 19, 2021 at 6:52 PM
    greger101
    greger101 [OP] New Member
    2006 tundra double cab 4.7 165,000 mi
    none
    I have a 06 double cab with 165,000. I just started getting a vibration at any speed that only happens when I'm on the gas. Goes away while off pedal and coasting in neutral. U-joints and carrier bearing replaced last year. Driving me nuts even though its not real bad...yet. Not an engine vibration I'm sure.
    YardBird likes this.
  2. Mar 20, 2021 at 6:19 PM
    Tsgrav2011
    Tsgrav2011 New Member
    Yuma
    2006 4D TRD 2WD
    Brush scratches and dents
    I am a little surprised a real mechanic has not hopped on this by now. In the meantime I can attempt to give you some ideas to consider. With the thought that the U-joints and carrier bearing was replaced last year I would start there. If your driveline indexing was kept, not rotated 1/2 turn the it might be a loose part. Apply your emergency brake, put your truck in neutral to unload any torsion on the driveline. Then check you carrier bearing bolts for centering, torque and any play in the vertical and lateral axis. Same with the U-joints. The vibe happens under rotational torque loading so look for lose part or if your carrier bearings alignment has moved off axis. Vibration is mechanical, the vibe is caused by movement in the driveline under load or torque, so a loose or worn part more than likely will be the source.
    mtndds98, YardBird and Jack McCarthy like this.
  3. Mar 21, 2021 at 7:15 AM
    Professional Hand Model
    Hand Protectors
    An aftermarket Carrier Bearing will only last less than a year at most from readings. Check to see if its deteriorated already.
    05-06 years have problems losing the transmission (mount) bolts on 2wd models.
  4. Mar 21, 2021 at 7:35 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  5. Mar 21, 2021 at 11:02 AM
    baltimorebirds2
    baltimorebirds2 New Member
    2004 Tundra Access Cab LTD 4x4 Salsa Red (TOTALED)
    When the driveshaft was taken off to replace the u-joints and carrier bearing, was it put back on exactly how it came off? There is a balancing weight of some sort on the driveshaft if I'm not mistaken, and it could cause some vibration if not put back on properly.
