vibration
Discussion in '2nd Gen Tundras (2007-2013)' started by gene, Dec 27, 2014.
  1. Dec 27, 2014 at 5:48 PM
    gene
    gene [OP] New Member
    Looking for some feedback on a vibration over 50 mph
  2. Dec 27, 2014 at 6:34 PM
    Can u please be more specific so we can try to help? Vibrations where?
  3. Dec 27, 2014 at 6:44 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Unbalanced tires/wheels is the typical cause of vibrations.
    ST3VE likes this.
  4. Dec 28, 2014 at 7:32 AM
    rebmo
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Check your e-brake mechanism under the rear passenger seat. Bad design, they get corroded and don't release. Rear wheels get hot if the e-brake is not completely released and shaking can occur at certain speeds. Just a possibility, that's a problem I had. Cleaning and lubricating fixed it. Dealer could not figure that out. Good luck.
  5. Dec 28, 2014 at 11:01 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Go ask for a dynamic road force balance, static wheel balances are useless.
  6. Dec 29, 2014 at 2:12 AM
    gene
    The whole truck shakes the steering wheel shakes . It starts about 50 mph. I started to notice it when I replaced p rated tires with lt 's . I have them spun balanced whenever there rotated.the tires r bfg's bout half tread left
  7. Dec 29, 2014 at 10:12 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    See reply above.
  8. Aug 15, 2015 at 3:41 PM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    NEEDS TO BE ROAD FORCE BALANCED
