Vibration when turning left from a stop
Discussion in '1st Gen Tundras (2000-2006)' started by shoe07, Apr 6, 2021.
  1. Apr 6, 2021 at 5:33 PM
    shoe07
    shoe07 [OP] New Member
    Ohio
    2004 Tundra Double-cab SR5 Tow pkg
    Good evening, I have an interesting symptom, I have a vibration which feels like it’s coming from the rear end. It happens when I turn left from a stop, especially noticeable at intersections. Sometimes it can be quite violent.
    When I’m towing the camper it continues to do it until I get the wheels straightened back out.
    Could this be an issue with the rear diff? A wheel bearing? Any checks I can do to figure out my culprit?
  2. Apr 6, 2021 at 6:39 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Is there any noise with the vibration? Place the truck in neutral, block the front tires. Jack the rear end up until the tires are off the ground and then try spinning the wheels (both sides). See if you can recreate any noises or rumbling stemming from the wheel bearings/ diff.
  3. Apr 6, 2021 at 6:52 PM
    How's the fluid level in the rear diff? Do you have the LSD rear end? The friction modifiers will wear out in the fluid and cause a less predictable operation. My 98 Blazer required 15k mile interval rear diff fluid changes.
    15whtrd and FrenchToasty like this.
  4. Apr 6, 2021 at 8:06 PM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    Just a theory, check the other end of your truck. You drag a trailer, your front end is raised. The axel boots could’ve worn out and damaged the axels. One of the symptoms of a bad front axel is shaking on turns. A bad axel will shake(50/50) on turns and is likelier to shake if you’re accelerating on the turn.
  5. Apr 7, 2021 at 3:19 AM
    shoe07
    Ohio
    Is LSD, fluid changed about 1500 miles ago, did it before and still does it. I’ve jacked up the rear and spun the tire but didn’t notice any thing, will repeat. I haven’t noticed any noise or rumbling, it only does it very briefly on the left turn from a stop.
    I replaced the passenger side CV axle, the boots on the driver side are ok, but I will look further into it.
    thanks for your ideas.
  6. Apr 7, 2021 at 2:48 PM
    sethcphoto
    sethcphoto First Gen Freak
    Seth
    Seattle, WA
    2005 Tundra AC
    If it will only make the noise/vibration when you put a particular load on it (ie turning left or towing) then it's probably a bearing issue.
    Voss likes this.
  7. Apr 7, 2021 at 4:42 PM
    shoe07
    Ohio
    I jacked up the front and rear and spun everything. Rocked wheels side to side and top to bottom. Didn’t notice anything abnormal.
    Think I’m just going to make an appt with my local mechanic for him to diagnose for me. Rather have it checked than play the replacement game or wait until it fails catastrophic when I’m 700 miles from home with camper in tow.
  8. Apr 7, 2021 at 5:03 PM
    Are the tires rubbing?
  9. Apr 7, 2021 at 6:50 PM
    shoe07
    Ohio
    No, doesn’t have to be full lock to do it.
  10. Apr 7, 2021 at 7:35 PM
    LASurf
    LASurf New Member
    Los Angeles
    300k+mi 06 AC4x4
    I have a similar symptom on a new to me 4x4 2006. From a stop and slow speed turning seems to be a vibration that transfers to the wheel. Interested to follow this thread and see what others have to offer.
  11. Apr 7, 2021 at 8:14 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    what gear oil did you use? sounds like chatter. Lucas HD gear oil is the only oil i've found to NOT chatter in my LSD diff
  12. Apr 8, 2021 at 4:02 AM
    shoe07
    Ohio
    Valvoline
  13. Apr 8, 2021 at 4:08 AM
    Professional Hand Model
    Hand Protectors
    A cheap fix would be go up to autozoned and buy a tube of limited slip differential additive. Pop the bung and squeeze 3oz in there. Drive it and see if it gets better. May need to add a little more, but start with 3oz.
  14. Apr 8, 2021 at 4:09 AM
    shoe07
    Ohio
    Is this the oil you speak of?
    empty_lord[QUOTED] and des2mtn like this.
  15. Apr 8, 2021 at 4:10 AM
    Hand Protectors
    Thats what I’ve been using. Yes. Check my above post, as well.
    des2mtn likes this.
  16. Apr 8, 2021 at 4:10 AM
    shoe07
    Ohio
    I may give that a shot this evening. Thanks for the idea. Will hold off on making a call to the shop another week and see if something like this sorts it out.
  17. Apr 8, 2021 at 4:15 AM
    Hand Protectors
    Yeah. Good call. This will at least confirm or deny the LS as a problem.
    I do remember having this slight chatter on slow speed turns from a stop when I used Mobil1 for LS (synthetic). It wasn’t violent like you say yours acts. Very subtle. Added the shtuff and it did subside, but would happen up less.
    Switched to Lucas and it very rarely happens, but sometimes I feel a little on rare occasion.
  18. Apr 8, 2021 at 4:21 AM
    shoe07
    Ohio
    Out of these is one better than the others?
    or should I order something specific off Amazon?
  19. Apr 8, 2021 at 4:31 AM
    Hand Protectors
    CRC is the go to on all things.
    DarkMint likes this.
  20. Apr 8, 2021 at 4:36 AM
    shoe07
    Ohio
    Looks like they have that at carquest nearby. Says KW on bottle but made by CRC. Maybe a regional thing. I’ll grab a bottle and try it for a few days and report back.
    Voss and Professional Hand Model like this.
  21. Apr 8, 2021 at 10:43 AM
    empty_lord
    05 rollover special
    Yup
  22. Apr 8, 2021 at 2:56 PM
    LASurf
    LASurf New Member
    Los Angeles
    300k+mi 06 AC4x4
    How do I know if my truck has LSD?
  23. Apr 8, 2021 at 3:02 PM
    Hand Protectors
    Look for a sticker on the rear diff.
    Jack McCarthy, BubbaW and Voss like this.
  24. Apr 8, 2021 at 3:12 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    If there is no LSD sticker like PHM suggested, go to Toyota Registration, create an account. Once logged in, add your veh via your VIN#. Once all that is done, look under "My Vehicle" then "Veh Specs". It would have an LSD entry if it was an option !
    Voss and shoe07[OP] like this.
  25. Apr 8, 2021 at 3:13 PM
    shoe07
    Ohio
    There is a good write up on here somewhere. I think @Darkness did it. You can also use your vin to look it up. My sticker was illegible, so the vin decoder is how I answered it.
    Voss likes this.
  26. Apr 8, 2021 at 3:14 PM
    shoe07
    Ohio
    Got some of this tonight sucked some fluid out of the diff, poured it in and topped off. Will report back in a few days if any difference noted
  27. Apr 8, 2021 at 3:14 PM
    Voss
    Valod
    2003 AC TRD 4x4
  28. Apr 8, 2021 at 3:23 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Find a large empty parking lot and do some large figure 8's to work the fluid into the clutch plates. On throttle on the straight portions and off throttle on the turns.
    FrenchToasty likes this.
  29. Apr 8, 2021 at 10:58 PM
    LASurf
    LASurf New Member
    Los Angeles
    300k+mi 06 AC4x4
    Thanks for all the replies. VIN lookup shows I've got the LSD. And the port exhaust tip listed was removed very early in my ownership.
  30. Apr 9, 2021 at 12:36 PM
    shoe07
    Ohio
    On the way home from work the two turns it typically vibrates it it did not. I went to a parking lot on the way home and attempted several time to get it to vibrate and no luck. Amazed that it appears to have worked after less than 20 miles. Fingers crossed but as of now it appears to be all good. Thanks to all who gave ideas.
