Vibration when accelerating from dead stop and turning
Discussion in '1st Gen Tundras (2000-2006)' started by 1st Gen Yota Guy, Mar 24, 2020.
  1. Mar 24, 2020 at 2:39 PM
    1st Gen Yota Guy
    1st Gen Yota Guy [OP] New Member
    Tony
    2002 Tundra SR5 Standard Cab 4x4
    Hey everyone,
    My 2002 tundra 4wd has developed a strange vibration. This only happens when I accelerate from a dead stop while turning, never when I accelerate going straight forward. It seems to be the worst when turning to the left and only happens when it’s a sharp turn. It also doesn’t seem to do it at low speeds, like turning into a parking space. The things I have checked so far:
    - it definitely isn’t locked in 4wd.
    - it isn’t tires rubbing.
    It feels like it’s coming from the rear end. Hoping it’s not a serious issue with the rear end, but have a feeling it could be.
    Anyone else have this issue and figure out what’s causing it? I’ve done quite a bit of searching and haven’t found anyone else with the exact same issue. Thanks in advance!
  2. Mar 24, 2020 at 3:47 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    When was the rear diff fluid last changed?
  3. Mar 24, 2020 at 3:51 PM
    1st Gen Yota Guy
    Tony
    October 2019 I changed the rear diff fluid and pinion seal. It had a little bit of a leak and the new seal took care of that.
  4. Mar 24, 2020 at 3:59 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    No metallic flakes?
  5. Mar 24, 2020 at 4:02 PM
    1st Gen Yota Guy
    Tony
    Nope, the fluid definitely needed changed, but no metal flakes.
  6. Mar 24, 2020 at 5:24 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    Did you use a new crush sleeve and take a bearing rolling torque reading before changing the seal and reset the rolling torque to the same specs. If not you may have damaged the pinion gear bearings.
  7. Mar 24, 2020 at 6:49 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    I had the same thing happen to me in my 02 with a limited slip. Don't say "LSD" or you will get some videos from members that will make you have a flashback even if you never tried acid. I was set straight LOl. Anyways I changed out the rear diff fluid with Lucas 80-90 heavy duty (recommended by a forum member) that comes with a limited slip additive and all was good. No more chatter. Good luck and hopefully this is all you need.
    bmf4069 likes this.
  8. Mar 24, 2020 at 6:58 PM
    1st Gen Yota Guy
    Tony
    PCJ - I did use a new crush sleeve, but didn’t take a bearing rolling torque reading. That’s a bit over my head, so hopefully I didn’t screw myself there.
    MS22 - thanks for the tip on the search terms lol. I’ll give the Lucas a try, I’ve never been disappointed by any of their products.
  9. Mar 25, 2020 at 2:43 PM
    1st Gen Yota Guy
    Tony
    Update: changed the fluid to the Lucas 80-90 for limited slip and the problem is 100% solved. I’m amazed there is that much of a difference, but glad that was the case. Easy and cheap fix for what I was thinking was going to end up being a major problem. Thanks guys!
  10. Mar 25, 2020 at 3:29 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Simple it was nice. Yeah it’s crazy that a small additive can make or break our rear diffs....they are more temperamental than a Beverly Hills housewife!
    MS22 likes this.
  11. Mar 27, 2020 at 4:57 PM
    Professional Hand Model
    Hand Protectors
    You haven’t met a Hollywood Hills wife!
    CodyP[QUOTED] likes this.
  12. Oct 25, 2021 at 12:54 PM
    bhorn0002
    bhorn0002 New Member
    2002 Toyota Tundra SR5 AC
    Having the same issue with my 2002. Fluid has been changed with the Lucas 80-90 Heavy Duty with the LS additive but there is still vibration when making a turn from a dead stop (left and right). Any other areas to check?
  13. Oct 25, 2021 at 1:30 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Do you have any noises or just vibration?
  14. Oct 25, 2021 at 2:08 PM
    bhorn0002
    @rock climber mostly vibration, but I can hear a bit of noise as I'm in the turn. Thinking about changing the Lucas oil again but adding a few ounces of additive as well just to see if that helps?
  15. Oct 25, 2021 at 2:52 PM
    rock climber
    Not a bad idea. I asked about the noise because it could be a bad wheel bearing, but they tend to always make noise, like a wuh wuh wuh kind of sound
  16. Oct 25, 2021 at 3:46 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    Have you checked your u joints? Take a look, if they bad you can those vibrations.
    Desert Dog likes this.
  17. Oct 25, 2021 at 4:33 PM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    X2 but typically a vibe from worn u-joints would be noticeable during straight-line acceleration and deceleration also. Worth checking the u-joints though.
    I would also check the transmission fluid level when it's hot and sitting at idle on level ground. May be a long shot based in your description of the conditions it occurs under but checking it would rule it out as a source. Keep us posted.
