Vibration when accelerating and turning
Discussion in '1st Gen Tundras (2000-2006)' started by Chaboo71, Jul 18, 2022.
  1. Jul 18, 2022 at 1:04 PM
    Chaboo71
    Chaboo71 [OP] New Member
    2002 tundra sr5
    Air bags
    Ok carrier bearing was shot
    So I replaced it. Since then and it was doing it alittle before I changed it and seems to be worse since I changed carrier bearing. I checked ujoints seemed fine greased them all. Over greased rear yoke but fixed that. Could I be missing a bad ujoint?
    Sorry people this is my first
    Forum subscription and don't know what I'm doing yet. I'm taking my drive shaft in to have it balanced. I'll try and do better and tell more about my vehicle next time and there will be a next time. I appreciate all the replies and would answer back but don't know how too lol.
  2. Jul 18, 2022 at 1:14 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Have you jacked up the front end and turned the wheels and tried to test them for play?
    Chaboo71[QUOTED][OP] likes this.
  3. Jul 18, 2022 at 1:14 PM
    Aerindel
    Aerindel New Member
    Montana
    CV joints could cause that. Classic symptoms at least.
    Chaboo71[OP], shifty` and alb1k like this.
  4. Jul 18, 2022 at 1:15 PM
    shifty` All my rowdy friends have settled down
    Can you tell us a little less about things? :rofl:
    Is it 4WD?
    Have there been any modifications to the suspension, i.e. lift, new shocks, struts, spacers?
    Have you checked the brakes?
    Do you live in the salt belt, i.e. deal with loads of rust?
    Chaboo71[OP] likes this.
  5. Jul 18, 2022 at 1:24 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Just to make sure but did you get it installed in proper orientation...."The carrier bearing is offset .625" and needs one round hole facing down and not 2 slots"
    Chaboo71[OP] and alb1k like this.
  6. Jul 18, 2022 at 1:36 PM
    alb1k
    Left Coast
    It's good
    If nothing else was changed but adding grease, seems like a possibility right here.
    but, I would think it’s only noticeable if the drive train was out of balance and or got worse by losing bolt/alignment orientation. I’m going with the turns part, that’s not usually high speed
    Chaboo71[OP] and BubbaW[QUOTED] like this.
  7. Jul 18, 2022 at 4:34 PM
    Chaboo71
    2002 tundra sr5
    Air bags
    I did mark the hole drive shaft and put it back together I thought the same it came apart. After alot of thought I remembered the video I watched before I did it said you had to pull ujoint closes to bearing which was wrong. I quickly put it back together not realizing when I was pressing ujoint back in place I flipped shift and never flipped back so it's 180 out. To be safe I'm taking shaft in and getting it balanced after I finish replacing ujoints. Thanks
  8. Jul 18, 2022 at 4:40 PM
    alb1k
    Left Coast
    It's good
    I need to balance mine I believe, but only for 80MPH+
    The drive shaft may be it, but vibrations and clunks and squeaks are often hard to diagnose...
  9. Jul 18, 2022 at 4:43 PM
    alb1k
    Left Coast
    It's good
    Which reminds me, my buddy with a 05 DC spent months trying to isolate a vibration. Finally a mechanic put it on a lift and put it in drive and spun the wheels at speed. It was driveshaft, and it made a shit ton of vibration.
    FrenchToasty likes this.
