Vibration at takeoff after lift
Discussion in 'Suspension' started by MogwaiBoogie, Oct 9, 2020.
  1. Oct 9, 2020 at 7:46 AM
    MogwaiBoogie
    MogwaiBoogie [OP] New Member
    Justin
    TEXAS
    2020 Tundra Platinum
    I recently had a 4.5 BDS installed on my 2020 4x4 and I immediately noticed that there is a slight but noticeable vibration at take off. Does not seem to do it from a slow roll or at higher speeds, just from a dead stop. Its not in the steering wheel or pedal, seems to come from the back end. Anyone else ever encounter this and been able to ID the issue?
    Couple of additional details. I am running blocks, did the carrier baring drop and am running 35x12.5s
  2. Oct 9, 2020 at 7:48 AM
    Shearboy2005
    Shearboy2005 New Member
    Wonder if carrier bearing drop needs slight adjustment
  3. Oct 9, 2020 at 7:48 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    What size of carrier bearing drop are you running?
    HulkSmurf14 likes this.
  4. Oct 9, 2020 at 8:21 AM
    MogwaiBoogie
    Justin
    TEXAS
    Honestly don't know, I just rolled with what the shop thought was necessary. Ill find out and give an update.
  5. Oct 9, 2020 at 8:22 AM
    MogwaiBoogie
    Justin
    TEXAS
    Seems to be the consensus so far. Ill have to run it back to the shop and find out.
  6. Oct 9, 2020 at 9:24 AM
    mountainpete
    Just go under and snap a pic with a ruler beside it
  7. Oct 9, 2020 at 9:26 AM
    mountainpete
  8. Oct 9, 2020 at 10:45 AM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    It’s probably from the CB location. Try a bigger or smaller CB drop kit. It’s kind of a cat and mouse scenario finding the right size drop as it appears it’s different from one truck to another. I’d suggest starting with smaller seeing as no drop is best (if you can do that without vibration of course).
  9. Oct 9, 2020 at 1:42 PM
    MogwaiBoogie
    Justin
    TEXAS
    Thanks everyone for the feedback. It is absolutely the carrier bearing. The shop that did the install is going to make the adjustments.
  10. Feb 28, 2023 at 4:19 PM
    Petergoose1
    Petergoose1 New Member
    2020 pro army green
    I put Coachbuilder 3” shackles on my 2020 pro with 3/4 cb drop and rear vibes like crazy on take off. I’ve taken the drop spacer off added washers and taken away with no help. Any ideas?
