Vibration at start up and weird vacuum sound at ignition shut off
Discussion in 'General Tundra Discussion' started by Wutachampion, Feb 19, 2018.
  1. Feb 19, 2018 at 1:46 PM
    Wutachampion
    Wutachampion [OP] New Member
    DFW
    used to own - 2016 MGM SR5 CM Texas Edition
    Hi guys,
    I didn't see a specific thread related to either of these so please if it's been answered before just share the thread.
    1. When I start up my 2016 CM, there's this weird vibration that happens with the truck. Generally lasts for about 5 seconds and goes away. It feels like the entire truck is shaking slightly.
    2. When I turn off the ignition, there's this weird sound coming from the passenger side engine/dash area. It almost sounds like a turbo or a vacuum sound.
    Has anyone had any knowledge of this? My car is still under warranty and I have Toyota extended care so want to make sure if it's something abnormal to take it in (even though I should and will do that regardless).
    Thank you.
  2. Feb 19, 2018 at 1:49 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    Can't help you with the shake part, but my truck makes the same sucking noise you are describing when I shut it off. I've heard the same sound on numerous Tundra's so I'm pretty sure its normal
    TheBeast and Wutachampion[OP] like this.
  3. Feb 19, 2018 at 1:51 PM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    Yep, same here. Not sure what it is. I’m sure someone who knows will chime in.
    Wutachampion[OP] likes this.
  4. Feb 19, 2018 at 2:50 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    I get a noise from the same area of my dash but it's more of a mechanical sound than a vacuum sound. Something related to the climate controls possibly. I also get a faint vibration at start up. It seems to be intermittet and is more apparent during cold weather. It lasts a few seconds or so and then fades and usually repeats 2 or 3 times. After the idle drops down it won't do it. Neither one seems to pose a problem but it would be nice to know what they are.
  5. Feb 19, 2018 at 3:26 PM
    lehminh
    lehminh New Member
    2016 Tundra SR5 CrewMax 5.7L 2WD Front Bench Seats
    Sounds like this is not a one off situation for you?
    I had a one incident of that happening, it hasn’t repeated and I couldn’t figure it out nor did anyone else say they experienced it; I started a short lived thread on this. So I can’t help but it seems uncommon. Next time it happens, record it and show it to dealer.
  6. Feb 19, 2018 at 3:40 PM
    Never heard of the shaking, but the sound you are describing is the air pumps. Completely normal.
  7. Feb 19, 2018 at 3:58 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Mine is just starting to vibrate somewhere by the p-side, it sounds like a heat shield thats loose but I think it’s cuz it’s cold most mornings now here in the CA desert. The vacuum sound is normal on all tundras, I believe it’s the AIP pumps(or called something else) doing what they’re supposed to do.
  8. Feb 19, 2018 at 5:56 PM
    Jim the Jarhead
    Jim the Jarhead New Member
    2017 SR5 4X4
    Your clutch fan, normal. Its plastic....at startup.
    Vacuum pump, normal. After shutoff.
    CB = cool beans
  9. Feb 19, 2018 at 7:10 PM
    Wutachampion
    DFW
    Thanks much sir.
