Vibration at low speeds under slight load - 2022 TRD LTD
Discussion in '3rd Gen Tundras (2022+)' started by PBNB, Nov 25, 2022.
  1. Nov 25, 2022 at 8:54 AM
    PBNB
    PBNB [OP] Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    We haven’t driven our Tundra much, mostly to pull the 4,500 lbs trailer. Our odometer reads 1,655km (about 1,000 miles). I noticed a vibration which is apparent in the seats. Feels like something is out of round or not connected. When I am slowly accelerating, it comes in at around 20 km/h and goes away as the speed increases. I haven’t really stepped on it as of yet. Trying to baby it for a while.
    Anyone else have this sort of vibration? Could it be the transfer case mounts or drive shaft? I guess we are off to the dealer already!
    We have a Long Box CrewMax TRD if that makes a difference.
  2. Nov 25, 2022 at 11:33 AM
    Lou1947
    Lou1947 New Member
    Tundra 1794
    Could be your tires out of balance
    mmasse and Durtywrench like this.
  3. Nov 25, 2022 at 11:44 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Cold tires
  4. Nov 25, 2022 at 4:40 PM
    PBNB
    PBNB [OP] Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I guess the tire balance could be out. it is pretty smooth on the highway at speeds up to and around 70 mph. I have the Michelin tires and have always had good luck with them as far as running round and true right from the start and our temps have been pretty mild up here when this happens. It seems to do the vibration when accelerating and at low speed but goes away quickly.
  5. May 12, 2023 at 5:31 PM
    Sarasotajon
    Sarasotajon New Member
    I will be heading to the dealership Monday with the same complaint. Shutter/vibration shows up at about 10 miles an hour and goes away.
    I thought it was from the transmission when it shifted from first to second gear. I put it in manual mode and kept it from shifting into second past 10 miles an hour and it's still occurred.
    It is very apparent and any service advisor that drives it should agree I do have a valid complaint and hope they find the issue.
  6. May 12, 2023 at 5:50 PM
    PBNB
    PBNB [OP] Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I was recalling my little 4x4 from the 90's. Under certain loads, the transfer case would move a bit. I wonder if that is what is causing the vibration?
