Vibration at 40-60mph
Discussion in '2nd Gen Tundras (2007-2013)' started by Optic15, Apr 30, 2024.
  1. Apr 30, 2024 at 8:08 PM
    Optic15
    Optic15 [OP] New Member
    SF Bay Area
    2011 White Tundra SR5
    Level kit Morimoto XB headlights & fog lights LED light bar behind bumper KMC XD wheels 18” 34” Cooper Discoverer tires Pioneer double din head unit 10” subwoofer - x2 Back up camera trunk latch
    So I just replaced my oil, rear differential fluid, rotated my tires and got an alignment yesterday. And I noticed at on the freeway today that at 40-65mp when I let off the gas I get a vibration. I also tested it from a stop light getting onto the freeway, I floored it from a stop to 55mph and let off the gas. Again that same vibration. The best way I could describe it. Is like having cupped tires, problem is my tires are newish and not cupped. I do know my u-joints could use a good greasing. My carrier bearing does have some up and down play when I push/pull my drive shaft. Does anyone have any other thoughts? It looks like my carrier bearing is original to my 2011 btw
  2. Apr 30, 2024 at 10:57 PM
    Mbril
    Mbril New Member
    Vibration when letting go off the gas is a strong sign of warped rotors.
    You don't always need to feel it while breaking for it to be the case.
    Also super easy to swap so worth a try.
  3. Apr 30, 2024 at 11:10 PM
    Optic15
    SF Bay Area
    I wish that were the case, I went and replaced all 4 sets of brakes less than 5k ago cause they were all due for pads so I figured rotors id do the rotors as well.
  4. May 1, 2024 at 3:55 AM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Take it back to the alignment shop...or a better one.
  5. May 2, 2024 at 1:23 PM
    justnutsandbolts
    justnutsandbolts New Member
    Check for signs of fallen weights from the wheels.
    That happened to mine during a rotation 2 years ago .
    Optic15[OP] likes this.
  6. May 2, 2024 at 1:28 PM
    Optic15
    SF Bay Area
    wouldn’t you be able to tell though at all speeds?
    I did find my carrier bearing is beginning to fail so im assuming that’s part of the problem and my u joints were in need of some greasing. As I haven’t greased them since I got the truck two years ago.
    Just greasing has made a noticeable change.
