Vibration after rear U joint install.
Discussion in '1st Gen Tundras (2000-2006)' started by Trapperpete52, Nov 29, 2021.
  1. Nov 29, 2021 at 10:15 AM
    Trapperpete52
    Trapperpete52 [OP] New Member
    Pete
    2002 Tundra
    2002 access cab. Found center carry bearing kind of loose and installed new. Then found the rear U joint was shot. while wrestling the drive shaft the yoke dropped out. Lined the splines up so the yokes all looked good and put back in. Major vibration above 30 MPH. My next try am thinking it must be 180 degrees out of time. Anyone have a better way to approach this?
  2. Nov 29, 2021 at 10:23 AM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Try moving the splined section 180 out. I found pics of zerk fitting direction online, and lucked out when i didnt mark my driveshaft, but all the balance weights are on the same side.
  3. Nov 29, 2021 at 10:25 AM
    Trapperpete52
    Pete
    2002 Tundra
    Thanks for the quick answer back. Going out now give it a shot.
  4. Nov 29, 2021 at 10:29 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Quick search, but it might have been this one.
  5. Nov 29, 2021 at 1:18 PM
    Trapperpete52
    Pete
    2002 Tundra
    Solved some dummy got a retainer clip in wrong groove that let the cap work back out about 1/8 inch.
    w666, bmf4069, shifty` and 3 others like this.
