(((VIBRATING))) Toyota Tundra
Discussion in 'General Tundra Discussion' started by duncanrc, Nov 13, 2024.
  1. Nov 13, 2024 at 5:52 PM
    duncanrc
    duncanrc [OP] New Member
    Duncan
    2014 SR5 Double Cab 2WD 4.6L
    (((VIBRATING))) Toyota Tundra 2014 RWD 200,000km. Vibration coming thru the body/seat: To address the issue I have replaced with new: Tires, Complete Front Brakes, U-Joints, Carrier Bearing. Vibration starts at low speed around 40kph continues up to hiway speeds. Vibration does not change with a different gear or under deceleration or acceleration. Truck is not driven offroad and has not had any accidents. Q: Diff issue? Was going to check for metal in diff. Maybe put truck on axle stands and drive. Any help or ideas? TIA
  2. Nov 13, 2024 at 6:00 PM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    Bent driveshaft?
    Driveshaft out of phase?
    Bent wheel? I doubt this because you just had tires put on.
    Shocks worn out?
    Any noise coming with the vibration?
  3. Nov 13, 2024 at 6:08 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    This list right here ^^^.
  4. Nov 13, 2024 at 6:28 PM
    SAGE63
    San Diego County
    Curious... anyone think moter mounts?
  5. Nov 13, 2024 at 10:17 PM
    duncanrc
    Duncan
    Thanks for the input
    Tomorrow I plan to jack the axle onto stand and run it to check for the vibration. I will also check for driveshaft alignment arrows. I may have to get new shocks to at least eliminate those. Vibration does not come with noise
    Also this truck has never been worked on except for brakes and tires
  6. Nov 14, 2024 at 2:39 AM
    2mchfun
    Driveshaft carrier bearing rubber surround decay?
  7. Nov 14, 2024 at 4:16 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    He said that it did not change with a different gear or with acceleration or deceleration. Motor mounts would.
    SAGE63[QUOTED] likes this.
  8. Nov 14, 2024 at 4:52 AM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    If you can feel it in the seat its likely from the rear end. Put it on the jackstands and check for a bent rim, bent axle, bent driveshaft. Tires are new but not always good. But you said the issue was present prior to new tires, so that seems unlikely.
  9. Nov 14, 2024 at 4:55 AM
    Half Assed
    Heartland Florida
    10 crewmax
    Does the speed of the vibration change with the speed of the vehicle? Typically a vibration from a rotating part increases in frequency with the speed of its rotation.
  10. Nov 14, 2024 at 7:06 AM
    2mchfun
    Oops, carrier has been replaced. Maybe somebody screwed up the u joint bearings or got the driveshaft out of order during reassembly? Those bearings in the caps can be stubborn.
  11. Nov 14, 2024 at 9:58 AM
    duncanrc
    Duncan
  12. Nov 14, 2024 at 12:43 PM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    No, that looks like the u-joint was installed incorrectly. The driveshaft should be true.
  13. Nov 14, 2024 at 1:23 PM
    DCRB4X4
    DCRB4X4 New Member
    BLACK 2015 DCRB SR5 4X4
    5100's front, spacer rear
    I had a new set of U joints bad from NAPA in a van. Changed to different brand and vibration went away. Felt in seat.
  14. Nov 14, 2024 at 1:53 PM
    2mchfun
    Use a dial indicator to see if it is even close
  15. Nov 14, 2024 at 6:31 PM
    duncanrc
    Duncan
    There is no doubt that the vibration I am feeling is the driveshaft. I returned the vehicle to the garage and they could see the ujoint was not sitting right. A new ujoint was installed and now all good. Even the pros get it wrong
    mverkaik and 2mchfun like this.
