Viair system
Discussion in '2.5 Gen Tundras (2014-2021)' started by Djez409, Oct 18, 2018.
  1. Oct 18, 2018 at 9:05 AM
    Djez409
    Djez409 [OP] New Member
    Rikki
    Port Arthur, TX
    2017 tundra sr5 4x4
    Anybody running a viair constant duty system? I’m trying to see some locations where I can mount the tank and compressor.
    Mountun Goat and papasmurf like this.
  2. Oct 18, 2018 at 9:10 AM
    Are you dead set on having a hard mounted air system?
  3. Oct 18, 2018 at 9:58 AM
    Djez409
    Rikki
    Port Arthur, TX
    2017 tundra sr5 4x4
    Yessir
    Mountun Goat likes this.
  4. Oct 18, 2018 at 10:03 AM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    yup
    tank in the bed and 450 compressor in the bedside
    Mountun Goat, equin, TheBeast and 5 others like this.
  5. Oct 18, 2018 at 10:17 AM
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    I have a viar tank with the arb twin compressor hard mounted. My tank is mounted infront of the spare tire with the compressor mounted under the passenger side back door. I'll see if I can get some.pics today . I do have my old viair compressor I could sell.
    831Tun and Djez409[OP] like this.
  6. Oct 18, 2018 at 10:22 AM
    Djez409
    Rikki
    Port Arthur, TX
    2017 tundra sr5 4x4
    I never thought of mounting the compressor there I like it!
    Duneflyer and papasmurf[QUOTED] like this.
  7. Oct 18, 2018 at 10:22 AM
    Djez409
    Rikki
    Port Arthur, TX
    2017 tundra sr5 4x4
    Pics would be appreciated bud!
  8. Oct 18, 2018 at 10:36 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    yeah when i was doing my bedsides it just made sense... that being said, not sure there is enough room under stock bedsides. So keep that in mind, i have fiberglass bed sides.
    Djez409[QUOTED][OP] likes this.
  9. Oct 18, 2018 at 10:40 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    My Viair compressor is mounted against the firewall under the hood on the passenger side, pulls air from the intake box behind the filter. The tank is mounted to the frame in the C channel under the passenger doors. The air chuck is up inside the fender well of the rear passenger wheel.
    Djez409[OP] likes this.
  10. Oct 18, 2018 at 11:29 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    When you wheel so hard you gotta carry backup leaf springs
  11. Oct 18, 2018 at 11:44 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Hahahahaha yeah right lol
    Sadly just had them stripped down for suspension cycling
    Djez409[OP] and Darkness[QUOTED] like this.
  12. Oct 18, 2018 at 12:47 PM
    Djez409
    Rikki
    Port Arthur, TX
    2017 tundra sr5 4x4
    I would really like a pic of this setup!
    trayday[QUOTED] likes this.
  13. Oct 18, 2018 at 12:48 PM
    Djez409
    Rikki
    Port Arthur, TX
    2017 tundra sr5 4x4
    Ima have to check when I get home
  14. Oct 18, 2018 at 1:57 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Last pic is of re routed front diff and transfer case breather lines since I had the hood open.
    20181018_134908.jpg 20181018_134929.jpg 20181018_135154.jpg 20181018_135214.jpg 20181018_135246.jpg 20181018_135227.jpg
  15. Oct 18, 2018 at 3:43 PM
    Djez409
    Rikki
    Port Arthur, TX
    2017 tundra sr5 4x4
    Sweet setup bro!!! Did you use another braided line to run from the compressor to the tank?
  16. Oct 18, 2018 at 3:49 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Haha, I'm mounting my tank there today.
    joonbug likes this.
  17. Oct 18, 2018 at 4:23 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    No, ran the plastic hose inside a fuel hose. Same to the air chuck. I need to do the same with the line to the rear differential.
  18. Oct 19, 2018 at 5:28 AM
    incredibillhulk
    incredibillhulk New Member
    Bill
    Last weekend I started installing my VIAIR 444C dual compressor system. This, along with the 8 gallon tank pictured in the bed below, are part of a system that will be used for my Hornblaster Nightmare train horn kit and to fill my airbags and tires as needed. The compressors are attached to the interior toolboxes of my A.R.E. MX shell with full walk-in back door and while they might seem to be in a strange place, that spot is just wasted space when the door is closed. I can basically fit one finger between the compressors and the door when it's closed.
    Ultimately I'll be moving the tank out of the bed and underneath the truck, this was just the path of least resistance for what I need through the end of the year.
    Mountun Goat, Dilsky, equin and 2 others like this.
  19. Apr 8, 2019 at 4:54 AM
    michaelsflowersjr
    michaelsflowersjr New Member
    Michael
    2019 Tundra TRD Pro
    Firestone airbags Daystar Air Bag Cradles
    Trayday I love your install, did you just bend that little horn or buzzer thing out of the way (right next to the air intake box) and did you just shoot sheet metal screws into the wheel well to secure that pump? I have the exact same pump. I don’t know what that buzzer or horn thing is, but mine seems like
    It would have to move to get my pump in there
  20. Apr 8, 2019 at 5:27 AM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    @trayday do you have a better pic of how you mounted the compressor
  21. Apr 8, 2019 at 7:07 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    I didn't do the install on that little black thing. I did relocate ground wires and cut up the wheel well so it shouldn't be an issue. @Berdine @michaelsflowersjr I'll take some more shitty pics later today and share them.
  22. Apr 9, 2019 at 12:10 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    20190409_120426.jpg 20190409_120426.jpg 20190409_120521.jpg 20190409_120506.jpg the small round thing that looks like a horn button was relocated to the double ground wires.
  23. Apr 9, 2019 at 12:40 PM
    Berdine
    Binghamton, NY
    @trayday thanks! Is that a custom mount? Or the one that comes with it?
  24. Apr 9, 2019 at 3:21 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    It's a custom mount
    Berdine[QUOTED] likes this.
  25. Apr 9, 2019 at 6:52 PM
    Berdine
    Binghamton, NY
    michaelsflowersjr and trayday like this.
  26. Apr 20, 2019 at 8:23 PM
    michaelsflowersjr
    Michael
    2019 Tundra TRD Pro
    Well I got my air compressor installed today. My kit is the Viair 10007 with the 2.5 gallon tank. I removed the back seats from the crewmax, and both fit nicely back there. I didn’t want to drill holes through the floor, so I went and bought some 3m velcro, I put it on the feet of the tank, I mounted the compressor on a piece of plywood, also screwed the on/off switch and air gauge on there. I didn’t take photos though. But the Velcro worked excellent with the carpeting can plug in the coil up hose on the passenger side. Also bent a piece of 3/8” stainless steel tubing for the drain with a stainless ball valve, so now it can drain water by pissing it outside instead of on the carpet. All in all I’m happy. That space behind the rear seat needs to be used, it sucks that you can’t access it easier. I’ll try to get a couple of photos of what you can see in the next couple of days maybe
    Berdine likes this.
  27. Aug 14, 2019 at 2:11 PM
    Dilsky
    Dilsky Toyota Brand *****
    Shawn
    Edmonton, Alberta
    2014 Platinum Tundra Crewmax Black
    King Front Coil-overs Coachbuilder shims Toytec Rear shackles - Stock Rear Baja Designs Sport Fog Lights Rough Country 30" Lightbar 18" Method Roost Wheels (Bronze) 285/70/R18 Nitto Exo Grapplers Diamondback HD Cover
    I have been looking at their heavy duty on-board air system. I am thinking of mounting it on the underside of my diamondback on the front panel, any thoughts on this vs an ARB system. ARB seems to be a higher price point but these seem like a better bang for your buck.
  28. Aug 14, 2019 at 2:34 PM
    michaelsflowersjr
    Michael
    2019 Tundra TRD Pro
    Only thing about that would
    Be needing to remove a panel and having it mounted to it, but maybe it’s not a issue. I think both the ARB and the Viair are both made in China compressors that are rebuildable. I’m big on made in USA, but that Viair compressor is good quality, I did buy a model that is continuous duty. I would think that is the most important part, but you can buy parts to rebuild it if you ever do. I have the crewmax cab and ALL of mine is mounted in the wasted space behind the rear seat. If I use it it is noisy, but normally you aren’t in the truck when you are using it. But it also breathes clean cabin air too. I think ARB builds great stuff but to me just way overpriced
    Dilsky likes this.
  29. Aug 14, 2019 at 2:39 PM
    michaelsflowersjr
    Michael
    2019 Tundra TRD Pro
    BTW I mounted the 2.5 gallon tank and the compressor there. I got some badass heavy duty 3m Velcro and it sticks to the carpet so well that you don’t need to drill any holes. On the compressor I mounted it on a small piece of plywood with the Velcro on the bottom and it sticks well too. I did that so the vibratory bushings where it screws down could properly compress like it’s supposed too, I also screwed that on off switch and gauge on that piece of plywood too, so you can open the rear drivers door and flip on the switch when your needing air
  30. Aug 14, 2019 at 4:18 PM
    Dilsky
    Shawn
    Edmonton, Alberta
    I am surprised you could fit that tank behind the seat, but I am guessing it is smaller than I am picturing in my mind. I am thinking I could mount the tank and pump here and it would not take up a lot of room.
