Viair 400 with hybrid battery
Discussion in '3rd Gen Tundras (2022+)' started by Hhtundra, Feb 23, 2024.
  1. Feb 23, 2024 at 3:32 PM
    Hhtundra
    Hhtundra [OP] New Member
    Was wondering if there are any concerns hooking up a viair compressor to the hybrid 12v battery under the hood? Have a 24 hybrid.
  2. Feb 24, 2024 at 7:58 AM
    Tho4x4
    Tho4x4 New Member
    2024 Tundra Limited Hybrid OR
    I also have a 24 Hybrid and have used the 12v battery under the rear seat to power my air compressor. Not sure if you’re supposed to but worked just fine
  3. Feb 24, 2024 at 8:15 AM
    As long as the circuit for the compressor is fused and that battery is on a charging cycle, I don't think it would be an issue. Shoot an email to Hornblasters and they will probably know. I'm sure they have done installs on hybrids.
  4. Feb 24, 2024 at 9:06 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    If you have a hybrid there is no battery under your hood. Your 12v starting battery is under your rear seat. Your hybrid battery is also under the rear seat and it is 288v and separate from your 12v starting battery.
    Kap1 and Mattedfred like this.
  5. Feb 26, 2024 at 6:14 AM
    Todd34
    Todd34 New Member
    I have the Viair 400P and I have used it by putting the alligator clips in the jumpstart terminal (POS) and ground under the hood without any issues.
