Very weird problem with brakes
Discussion in '2nd Gen Tundras (2007-2013)' started by dav89d, Jun 22, 2016.
  1. Jun 22, 2016 at 8:03 PM
    dav89d
    dav89d [OP] New Member
    To make the long story short after plugging in my scanner to reset check engine code all the lights on my dashboard that have to do with brakes (brake, abs, traction control and vsc light) are on. Vsc is flashing. I checked the fuses under the hood for abs but those are fine. My question is is there like a brake module that controls all of that that may have burned up or are there separate modules that control different things? and it's not like only the lights are on. Abs doesn't work traction doesn't work. If someone can steer me in the right direction or possibly had this issue plz help. thank you in advance
  2. Jun 22, 2016 at 8:36 PM
    Whats the CEL code?
  3. Jun 22, 2016 at 8:51 PM
    dav89d
  4. Jun 22, 2016 at 8:51 PM
    Check engine light
    U mentioned clearing it
  5. Jun 22, 2016 at 9:04 PM
    dav89d
    Oh someone stole my gas cap and I was driving without it for some time so my check engine light went on. When I finally replaced it I tried deleting my code and that's when it happen
  6. Jun 22, 2016 at 9:45 PM
    dav89d
    And let me add on to this. Who ever owned the truck before me they were running power from traction control switch to a separate switch which controlled all the LED lights around the truck and in the bed. Is it possible that when I was looking for the obd port I may have shorted something out?
  7. Jun 23, 2016 at 6:21 AM
    Just to confirm, there is no current CEL on, correct? Just the abs / traction?
  8. Jun 23, 2016 at 6:22 AM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Hmm, well if you've got a flashing light you've probably still got a code. If you can tell me the code I could give you some more detailed information.
  9. Jun 23, 2016 at 6:22 AM
    Nor7
    Also, need to know the year model, cab style and engine of your tundra.
  10. Jun 23, 2016 at 3:57 PM
    dav89d
    No check engine light or any engine codes what so ever. Like I said vsc off is blinking and brake abs and traction control are constantly on. Manufactured in June on 07 5.7L twin cab
  11. Jun 23, 2016 at 4:31 PM
    Sensor is bad or some fuse me thinks.
  12. Jun 23, 2016 at 4:31 PM
  13. Jun 23, 2016 at 4:44 PM
    dav89d
    I checked abs fuses under the hood. Those are ok. Is there a fusable link somewhere? A module that controls all that?
  14. Jun 23, 2016 at 4:46 PM
    swede78
    swede78 Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
    If you just put on the new fuel cap drive it for a while,I believe the lights are on because the other cap was off,has something to do with evap system. Lights should go out after driving a bit, let us know.
  15. Jun 23, 2016 at 4:53 PM
    dav89d
    But the lights have nothing to do with check engine. They all turned on the second I plugged in my scanner to check y I have cel. Cel has been taken care of.
  16. Jun 23, 2016 at 5:01 PM
    Mike Tread lightly.
    south carolina
    If the abs light is on you have a fault. Most scanners can't go that deep into ecm.
    You need to get a scanner(does abs) or have a shop that can pull the code. If anything you might have a bad wheel sensor for the abs going out.
  17. Jun 23, 2016 at 7:32 PM
    manbearpig
    manbearpig New Member
    2016 tundra
    could be a strange coincidence but when i first plugged in my ultra gauge my abs lights came on until I restarted the truck a couple times dont know if something with the obd2 port can trigger it
  18. Jun 23, 2016 at 7:35 PM
    Mike Tread lightly.
    south carolina
    For the ultra gauge I believe you had to depin one of the pins to keep abs light from coming on.. I read that somewhere. I believe.
  19. Jun 23, 2016 at 8:40 PM
    manbearpig
    2016 tundra
    thanks Ill have to look into it, it only did it the first time starting it after the install, have a 1500 miles since.
  20. Jun 23, 2016 at 9:32 PM
    dav89d
    I tried disconnecting the battery to restart all the modules. As soon as I hook the battery back again all the lights on my dash come back. And it's not like it's just a dash problem. Abs doesn't work traction doesn't work. That's why I'm asking is there a single device/module/computer that controls all that shit that may have go bad when I hooked up my scanner or maybe my scanner created a short somewhere in the harness and blew a stupid fuse that I don't know about. Like I said In my introduction post. Im a diesel mechanic and I've dealt with problems just like this, where abs, traction control goes off and there is a module 99% of the time that controls all of it.
  21. Jun 23, 2016 at 9:33 PM
    dav89d
    I don't want to just make the lights go off on my dash. I want this problem fixed the right way that's why I turn to you guys who have way more experience with these trucks
  22. Jun 23, 2016 at 9:33 PM
    Nor7
    Try to get your hands on a scanner that can read the ABS system.
  23. Jun 23, 2016 at 9:37 PM
    dav89d
    i tried bro. I have programs on my laptop for any air brake system imaginable but it's all J1939 for big commercial and heavy duty trucks. I can't find a scanner with obd2 port that can scan brake systems. Where don't even look?
  24. Jun 23, 2016 at 9:38 PM
    Nor7
    Might be the VSC switch itself, here's an inspection procedure.
  25. Jun 23, 2016 at 9:39 PM
    Nor7
    My scanner does ABS, I'll check in the morning the brand name.
  26. Jun 23, 2016 at 9:40 PM
    dav89d
    What exactly is vsc? I know it's a dumb question proly but I'm still trying to figure this truck out
  27. Jun 23, 2016 at 9:42 PM
    Nor7
    Also found this, may be worth a check.
    Trouble Code: C0273/13 (5.7L V8 VIN - Auto)
    Open in ABS Motor Relay Circuit
    Print this code data[​IMG]
    • ECM Details
    Trouble Code Conditions:
    When one of following conditions is met: 1. Pump motor voltage is 2.0 V or more for 1 sec. or more at motor relay OFF. 2. Pump motor voltage is (IG - 4.0 V) or less for 0.1 sec. or more at motor relay ON. 3. After the end of the actuation of the motor relay, slow down condition of motor does not meet the specification.
    Possible Causes:
    • * ABS1 H-fuse
    • * Harness or connector (+BM circuit)
    • * VSC actuator (skid control ECU)
  28. Jun 23, 2016 at 9:44 PM
    Nor7
    Ah, here's what I was looking for. An exhaustive inspection procedure for the VSC light stuck on.
  29. Jun 23, 2016 at 9:45 PM
    Nor7
    Vehicle Stability Control
  30. Jun 23, 2016 at 9:48 PM
    Mike Tread lightly.
    south carolina
    Techstream software which is Toyota software will do it. It's what the dealer's use... it's pricey tho.
    You did check the fuses in the dash correct?
