Vent Visor - In-Channel vs. Tape on
Discussion in 'General Tundra Discussion' started by avi8r2009, Mar 13, 2018.
  1. Mar 13, 2018 at 12:42 PM
    avi8r2009
    avi8r2009 [OP] New Member
    Jack
    2018 Black Tundra
    I'm a new Tundra owner and want to install vent visors to reduce noise.
    I'm looking at AVS from RealTruck and was wondering if anyone has an opinion on In-Channel vs. the Tape on attachment.
  2. Mar 13, 2018 at 12:49 PM
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    go inchannel they last so much better and do not mess up your windows , I had them on many trucks and love them . I have weathertechs . Look at how many tape on's have come off / broken and what they look like .
  3. Mar 13, 2018 at 12:52 PM
    I have in channel weathertechs no issues have tape on inside love em
    SouthBoundSteve likes this.
  4. Mar 13, 2018 at 12:53 PM
    Welcome from Texas
  5. Mar 13, 2018 at 12:57 PM
    kurtwp
    kurtwp What
    Kurt
    Charlotte, NC
    2016 Tundra Limited TRD 4x4 Off Road DC
    I have the in channel AVS system. The channel system still has tape when you install the visors
    Kurt
  6. Mar 13, 2018 at 1:05 PM
    blizz86
    blizz86 New Member
    You will likely notice an increase in wind noise with the visors.. that was my experience with them
    Luckydog and Mountun Goat like this.
  7. Mar 13, 2018 at 1:07 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Agreed
  8. Mar 13, 2018 at 1:11 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
  9. Mar 13, 2018 at 1:12 PM
    RickC
    RickC NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    I prefer the in-channel. I had one set that actually messed up the window regulator and oddly enough, it was on my 2006 Tundra that I bought new. When I sold that truck, the window regulator had slack in it to where it would drop a little when rolling down the window. I have never had that happen on any car prior or after that. However, my last two sets that I have bought have been the stick on, but they are noiser and don't look as good in my opinion.
  10. Mar 13, 2018 at 1:21 PM
    Diverguy
    Diverguy Breathes under water
    Leon
    PA, USA
    2018 Tundra Limited TRD Offroad-Inferno
    Windows tinted, window visors. Bedrug, led bedlights, Nfab nerf step bars, Lund toneau cover, Evo One remote start, BAMufflers 8"
    I have the tape-on from AVS. I had the same ones on my '13 Tundra. The only issue I ever had was when my wife opened her door too close to a tree and smashed the visor. I was able to pop it off using a little heat from a blow dryer. No damage to the paint underneath. I installed the same ones on my '18
  11. Mar 13, 2018 at 1:30 PM
    Wutachampion
    Wutachampion New Member
    DFW
    used to own - 2016 MGM SR5 CM Texas Edition
    Yeah I didn’t understand what the OP meant by reducing noise? Can you clarify @avi8r2009
  12. Mar 13, 2018 at 1:53 PM
    Johnathand
    Johnathand New Member
    Johnathan
    16 Platinum
    I have the tape on. AVS LOW PROFILE. I like them because they flow nicely with the body and window lines of the truck. Had them for 5 months. Been thru a harsh winter and no issues. Doesn’t increase or declcrease wind noise.
    7F357857-4706-4E98-9D89-B0FB79B155CA_zps_52d2d07437040c4412d9364be44570ce571d629e.jpg
  13. Mar 13, 2018 at 1:55 PM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    in channel AVS.. had on my 2015 as well.. absolutely no complaints, about 5-10min complete install
  14. Mar 13, 2018 at 3:11 PM
    blizz86
    blizz86 New Member
    Those look pretty clean..
  15. Apr 28, 2019 at 9:03 AM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    Bringing this back to life. Wouldn’t the in channel one cause stress on the window and motor when the window reaches the vent since it’s prob a super tight space after install?
  16. Apr 28, 2019 at 9:22 AM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    In channel
    WodenTX likes this.
  17. Apr 28, 2019 at 9:55 AM
    Professional Hand Model
    Hand Protectors
    I bought and installed the Weathertechs. It was tight after the first few days. I then removed them and really cleaned out the track system all the way around the clock as best possible. After cleaning, I then sprayed PB Blaster with Silicone and Teflon all the way around and wiped some on the friction side of visor/window and re-installed the new visors. No problems after this. The silicone and Teflon properties work best AFTER they dry.
  18. Apr 28, 2019 at 10:35 AM
    cmiller219
    Nashville, TN
    Seems like a lot of work for something that is designed to just go into place
  19. Apr 28, 2019 at 11:33 AM
    Hand Protectors
    The visor is designed to fit into place.
    The window is not designed to fit a visor in place.
    If you want visor, then you follow the steps I suggested to make it work properly (as best optimized).
    Nothing is easy.
  20. Apr 28, 2019 at 12:25 PM
    cmiller219
    Nashville, TN
    Yeah that was what concerned me that channel belongs to the window and prob doesn’t like roommates hahha. I have always had the regular ones but was considering in channel ones but didn’t want to put strain on anything
  21. Apr 28, 2019 at 1:31 PM
    Bheid
    Bheid It's not a toy, it's a Toyota.
    Doug
    Indiana
    2016 Black Tundra SR5
    Fab Fours Black Steel Elite front bumper Rhino Lined Bed Century Truck Cap Bridgestone KO2 tires K Source tow mirrors Blackvue Dashcam
    I have in channel AVS been on the truck three years no issues with window motor. The only thing is very minimal scuffing of the top most edge of the window, but nothing you really notice unless you are looking for it.
  22. Apr 28, 2019 at 1:34 PM
    I've used both types over the years. Both have their pluses and minuses. They both served their purpose quite well.
  23. Apr 28, 2019 at 1:41 PM
    nvrgvup444
    nvrgvup444 New Member
    KCMO
    2015 Dbl Cab Limited - Blue Ribbon
    Bilstein 5100 all corners, Toytech Shackles, Nitto Ridge Grapplers, Completely new sound system that sounds great but didn't cost an arm and leg, front camera, front receiver hitch
    AVS in-channel is what I have. No problems or complaints.
  24. Apr 28, 2019 at 2:08 PM
    Hand Protectors
    My visors are working very well no scuffs even with Ceramic Tint.
    PB Blast Silicone with Teflon is your friend.
  25. Apr 28, 2019 at 2:39 PM
    Ditto.:thumbsup:
  26. May 8, 2019 at 8:32 PM
    cmiller219
    Nashville, TN
    Going with the stick on visors. They seem to nothing but positive reviews. The in channels have great reviews too but they have what seems to be more issues with falling out and causing stress on the window. The falling out part is an issue for me.
  27. May 22, 2019 at 12:12 PM
    Twisted99
    Twisted99 New Member
    2018 Crewmax Platinum 4x4
    None, yet
    I've had in channel AVS on both of my Tacoma's. Well over 200k between them.
    Never any issue with windows or regulators.
    Unfortunately AVS does not make in channel for my 06 DC.
  28. Aug 26, 2019 at 8:19 PM
    babygirl9272
    babygirl9272 New Member
    I have asked pretty much the same thing as I had ordered the in-channel and outside mounting ones. I've done a lot of research on these and I have pros and cons on both of them and after last week...just decided to go with these in-channel ones. There is a lot I like about the ones that fit on the outside, but I figured my best option was to go with the in-channel ones, so I didn't have to worry about the "removal" process of them from the outside, if I was truly unhappy.
