Veepeak OBD2 Scanner / Trans Temp
Discussion in '2.5 Gen Tundras (2014-2021)' started by charliebison, Apr 16, 2021.
  1. Apr 16, 2021 at 6:01 PM
    charliebison
    charliebison [OP] New Member
    Any idea how I can get transmission temps to show with the Veepeak scanner and the OB2 Fusion app with the upgrade option? Is it an option? I can’t figure it out for the life of me.
  2. Apr 16, 2021 at 6:11 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
  3. Apr 16, 2021 at 6:23 PM
    Patrick shows how to set it up in the video. It's really easy. Start watching at the 32 minute mark.
    https://youtu.be/5DLkja6vXvc
    CC TIGER likes this.
  4. Apr 16, 2021 at 6:53 PM
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    I added the Toyota extra codes for about $40 to the Fusion app, I forget exactly what it was called, but it popped up and I bought it. Then I found the Tran 1 and 2 options for the temp. Took a little, but worked out well with my Veepeak. Before I bought the add on, I could not find anything. Then when I connect, I scroll to Network A on the app and set up my dashboard with the items I wanted, trans temp 1 & 2, engine oil temp, coolant temp and charging volts.
  5. Apr 16, 2021 at 7:13 PM
    charliebison
    Thanks, I’ll check it out.
  6. Apr 16, 2021 at 7:14 PM
    charliebison
    I bought the extra codes but there’s nothing for the trans temps. I’ll keep digging. Thanks!
  7. Apr 16, 2021 at 7:46 PM
    The trans temps are what he sets up in the video after the cool install.
  8. Apr 16, 2021 at 8:24 PM
    Pmac
    Pmac New Member
    Iirc there were two sets of Toyota codes, the more expensive ones came with the tranny codes for me. All I had to so was select them as part of my dashboard. Good luck!
  9. Apr 16, 2021 at 9:56 PM
    charliebison
    Perfect. Thanks!
  10. Apr 17, 2021 at 5:50 AM
    a522467
    a522467 Life’s short. Live now.
    Michelle
    Ohio
    2020 Black Tundra Doublecab 4X4 SR5 with SX pkg
    Rear spring upgrade, rear shock upgrade, front & rear sway bars, bed step, bed mat, console organizer & tray, black lug nut covers, rear underseat storage box, black seat covers, Bluetooth CarPlay adapter, LED fogs, blue footwell lighting, LED cargo, reverse, tail, and stop bulbs, tinted tail and 3rd stop/cargo lights, tinted glass all around, tinted front emblem, matte black tailgate emblem inserts, retractable tonneau cover w/trac system and load bars, front facing camera, 8” exhaust upgrade, LED bed lights, 8-ball shifter knob, shifter boot, LED headlights, custom wheel center caps, 3”x30’ tow recovery strap, bed rail clamps, LED puddle lights, phone mount, OBD2 scanner, touchscreen glass protector/overlay, trailer hitch lock, tire traction aid, tinted license plate cover, power relay module, 6-way fuse block with cover, stainless mesh cowl screens, LT265/70R18 A/T tires, driver’s side swing case toolbox, dual air horn kit, rear Husky Liner, cat converter theft deterrent covers, front & rear dash cam, LED tail light bar, trailer plug wiring harness, locking fuel door, matte black interior door handles, glovebox & fuel door keyhole decals, TUNDRA sill plates decals, chalk bag cup holder / trash can, HD Roadmaster active suspension kit, HD front struts, Backlit window control panel, tailgate gap cover, matte black radio surround. https://www.tundras.com/threads/740-yota-2020-sr5-4x4-dc-w-sx-pkg.79742/
    For anyone with a wireless CarPlay adapter, get the BlueTooth version of the Veepeak OBD2. The Wifi version interferes with the CarPlay adapter. I'm using the Veepeak BLE+ in my '20. You can make custom PIDs as described in the video, or opt for the $10 ODB Fusion adder and find the temps in the list.
    Terndrerrr likes this.
