Various spacer sizes form hardware store for lift....
Discussion in 'Suspension' started by Nativeimages, Apr 6, 2021.
  1. Apr 6, 2021 at 5:11 PM
    Nativeimages
    Nativeimages [OP] New Member
    Willard
    2018 Tundra 1794 Edition
    Bought a bunch of different size spacers with different diameters for the differential....skid plate and drive line carrier bearing drops....all different lengths and sizes...what ever I don’t use I will return for refund....all machined stainless steel....or just steel...any thoughts?.....
  2. Apr 6, 2021 at 5:35 PM
    Lol....you could have just asked what sizes are needed for the lift that you are getting. :notsure:
  3. Apr 6, 2021 at 6:27 PM
    I wouldn't use any of that hodge podge for a diff drop or carrier bearing drop. Where are the longer bolts, nuts that you need and proper sized washers? There are several vendor's here that sell diff/carrier bearing drop kits. I'd return everything you bought. @Toytec Lifts
  4. Apr 7, 2021 at 9:50 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Just purchase a correct drop kit as needed, they will be all correct fit and correct grade materials. And they do not cost much. I would not try and hobble together something yourself, you are not going to save much $ and if the items are not good quality and the correct grade material you are looking at problems.
  5. Apr 7, 2021 at 10:14 AM
    Nativeimages
    Willard
    I heeded the members advice and purchased carrier bearing drop kit....differential drop and skid plate drop kit....front sway bar drop spacers and brake line extension and abs relocation extender kit....that should take care of the drops and extensions for best chance of success for alignments for 2 to 3 inches of lift.....rear icon w/resi and CDC....set of SPC UCA’S....set of add a leaf springs for 1.5 to 2 inches of lift in the rear...I already have the front icon struts with resi/CDC with up to 3 inches of lift in the front....1/4 inch shims x 2 for the drivers lean....so everything should be here by next week....then All I need is an installer....and bigger tires....275/80r/18 on stock 1794 wheels....we’ll see how everything comes together by the end of April....that’s the soonest I predict for the install....thank you for the advice...
    Black Wolf likes this.
  6. Apr 7, 2021 at 11:11 AM
    Sounds like a good plan!:thumbsup:
