Valve Job or engine swap?
Discussion in '1st Gen Tundras (2000-2006)' started by MJonesSD, Dec 28, 2021.
  1. Dec 28, 2021 at 11:51 AM
    MJonesSD
    MJonesSD [OP] New Member
    2006 Tu dra
    I have a 2006 Tundra 4.7 double cab in good overall shape 280K that appears to have leaking valve seals, cold start I get a solid blast of white blue smoke that goes away shortly after... I have had this truck from day one and honestly can’t afford to replace the truck, I love this truck and body style
    Valve work I am looking at roughly $2.5k. I do have a possible main seal leak as well or leaks in both pans can’t confirm. I can get a low mileage A grade 4.7 for $2.6K with about $1.5k labor. Dos it make sense to replace the motor? My worry is what gremlins would I encounter with a swap? It’s a CA truck and found a matching motor but out of state (CA emissions)
    A Toyota specialist mechanic says valve work, but another well respected mechanic says do the swap?
  2. Dec 28, 2021 at 11:58 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I had a similar predicament with my wifes Honda. I wanted to pull the head myself and have the valve work done, then put it back together myself. The trouble became I never found the time.
    Everybody I asked said just swap the motor. Eventually that's what I did, or rather had a mechanic do. The motor swap was really just the long block. Everything that bolts to the motor was swapped over and the seals were replaced during the swap. So far no problems.
    As far as the CA emissions I don't think there is a difference in the motors. I have read that CA trucks had 3 catalytic converters where other states had 2, however my truck is originally a CA truck and only had 2.
  3. Dec 28, 2021 at 12:02 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Swap,,, that way you are starting out semi fresh all around. Best of luck and hope it goes smoothly
    MJonesSD[OP] likes this.
  4. Dec 28, 2021 at 12:03 PM
    MJonesSD
    2006 Tu dra
    Ok thanks for the insight, so positive for the swap.
    I am leaning towards the swap as I do get an occasional cold start knock as well goes away in a minute under load.
    Black@Blue19 likes this.
  5. Dec 28, 2021 at 12:34 PM
    tvpierce
    tvpierce Formerly New Member
    Maine
    A valve job requires removing the head and grinding valve seats. Valve guide seals are a relatively minor deal. I haven't done them on this engine, but when I've done them on other engines, it only required removing the valve cover, not the head.
    Aerindel and Darkness like this.
  6. Dec 28, 2021 at 12:38 PM
    MJonesSD
    2006 Tu dra
    The two mechanics I spoke with said they need to pull both heads to replace valve seals and do a once over the heads
    Darkness likes this.
  7. Dec 28, 2021 at 1:25 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Have you checked the PCV valve for sticking or plugging?
    How much oil are you having to add, and how often? Or is the smoke the main symptom?
    txagg likes this.
  8. Dec 28, 2021 at 2:09 PM
    MJonesSD
    2006 Tu dra
    Yes replaced PVC and did a full sea foam clean. Burning a decent amount of oil
  9. Dec 28, 2021 at 5:54 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    Some smoke at start up on a 280k motor. Unless you're starting the truck in your bedroom I don't see this a major problem. I certainly don't see it as a problem needing to spend $4,100 on a used motor that may smoke just as bad once installed or have a host of even worse problems. This sounds like a big gamble especially since money is tight as you say.
    I'd do a little more diagnosis, pull the spark plugs, run compression on the cylinders, could be just some bad rings on a cylinder or two and not valve seals. How's your coolant level? With the newer oils it's pretty hard to distinguish oil smoke from coolant being vaporized, at least to my old eyes.
    txagg likes this.
  10. Dec 28, 2021 at 6:25 PM
    MJonesSD
    2006 Tu dra
    It can be a lot of smoke at start, pretty good cloud.
    It’s not coolant.
  11. Dec 28, 2021 at 6:51 PM
    shifty` I'm having daydreams about night things
  12. Dec 28, 2021 at 7:53 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
  13. Dec 28, 2021 at 8:24 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
  14. Dec 29, 2021 at 9:19 AM
    MJonesSD
    2006 Tu dra
  15. Dec 29, 2021 at 10:26 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    txagg likes this.
  16. Dec 29, 2021 at 11:31 AM
    MJonesSD
    2006 Tu dra
  17. Dec 29, 2021 at 11:43 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    I've tried the Lucas too, the ATP seems to have more reliable results.
  18. Dec 29, 2021 at 11:45 AM
    MJonesSD
    2006 Tu dra
    Ok might give it a try thanks
  19. Dec 29, 2021 at 11:49 AM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    Try the AT-205, supply chain issues might make it a little hard to find right now. The ATP has plasticizers that restore plastic/rubber, complete different animal than the Lucas junk. I would empty the crap you have in it and put an OEM weight synthetic oil. Drive it a tank of gas with the new oil, then add the ATP and drive it another tank of gas or so with it and see if your consumption lessens. After 1k miles or so goto a higher weight oil and see its working for you. If you still look like you're rolling coal on startup, figure out if its valve seals, valve gaskets, or rings. If it's seals, I remember reading about changing them with the heads on with string or something on ih8mud.
    shifty` likes this.
  20. Dec 29, 2021 at 11:54 AM
    MJonesSD
    2006 Tu dra
    Thank you!
  21. Dec 29, 2021 at 1:49 PM
    tvpierce
    Maine
    Yes, it’s a simple process. That’s what I was getting at a ways back. If it’s just valve guide seals, you remove the valve covers, get the engine so cylinder-1 is at the bottom of the compression stroke, remove the spark plug, stick a couple feet of cotton clothes line at in the cylinder through the plug hole (leave a length sticking out of the hole so you can pull it out when done) then slowly turn the crank until the rope bunches up and is lightly compressed against the head/valves. This keeps the valves from dropping down into the cylinders when you release the keepers. Remove the keepers, replace the seals and reinstall the keepers. Do one cylinder at a time until you’ve done them all. As I said, I haven’t done this on a Toyota but have done it on two European engines and stopped the oil consumption and smoke at start-up.
    txagg[QUOTED] likes this.
  22. Dec 29, 2021 at 2:25 PM
    terrward
    terrward New Member
    2004 DC SR5
    If it’s just a minor puff of smoke during startup and goes away I wouldn’t bother fixing it. 2.5k to 4K buys a lot of 1qt bottles of oil for topping it up.
  23. Dec 29, 2021 at 3:47 PM
    remington351
    2006 SR5 DoubleCab
    The 2uzfe is not a OHV Ford or Chevy. The crux of this repair is the labor involved in removing the cams in order to remove the buckets to then get to the valve stem seals. I'm not aware of many, or any, posts on the forum of guys DIY'ing cam removals on a VVT engine. It seems to be a very intricate affair.
    This guy at the Lexus forum did a detailed write up.
    Good luck.
    https://www.lextreme.com/how-to-replace-toyota-and-lexus-valve-seals/
    Mogo Gogo likes this.
  24. Dec 29, 2021 at 6:18 PM
    Aerindel
    Aerindel New Member
    Montana
    Man, it really looks like just pulling the heads would be worth it at that point.
  25. Dec 30, 2021 at 6:27 AM
    tvpierce
    Maine
    That's a great write-up.
    Here's another one on a Toyota 4 cylinder... it's the same process (just half the cylinders), but he uses the rope method to hold the valves and has a different tool. Just another resource.
    https://www.toyotanation.com/thread...ement-without-removing-cylinder-head.1429378/
    Whether the heads come off or not, you still have to remove the cams and shims. I don't think removing the heads really gains you anything.
  26. Dec 30, 2021 at 10:43 AM
    EvilMilkshake
    EvilMilkshake New Member
    05 AC Limited 4x4
    I removed the cams a few months ago. It's not that bad of a job to get there, but basically adds onto doing a regular timing belt replacement. Just followed the FSM. After removing the T-belt, you take off the valve covers, remove the cam caps, then the cams. I had a leaking cam seal on the passenger side, so replaced both. All in all, it added about 3 hours on top of just doing the T-belt. The cleaning of the sealant took the longest, but that's the same as having to do just the valve covers.
