Valhalla’s Shield theft deterrent/skid plates info and ordering post
Discussion in 'Valhalla’s Shield' started by Classy63, Mar 8, 2021.
Thread Status:
Not open for further replies.
  1. Mar 8, 2021 at 6:49 PM
    Classy63
    Classy63 [OP] Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    My name is Tyler and I am the creator of Valhalla’s Shield. I make catalytic converter theft deterrent plates that can also be used as skid plates in the thicker version. I currently only make these for the 2007+ Tundra and 2008+ Sequoia.
    These plates will not fit a lift bigger than 4” lift like the Readylift. The aftermarket subframe lifts will not fit the standard plate. I do however make a plate that fits the Procomp and Readylift. I would ask for verification for fitment.
    For purely theft deterrent purposes 1/8 steel and 3/16 aluminum for the bill. For those that want these as a skid plate aswell, I recommend 3/16 steel or 1/4 aluminum.
    The standard plate will fit a TRD PRO factory skid plate, it is a tight fit getting a tool or hand in there to hold the nut while tightening the bolts thought.
    To be clear, I make a Front catalytic converter plate/transmission plate and a rear catalytic converter/transfer case plate.
    https://valhallasshields.com/
    Below is all pricing for my plates shipped. If you are local to Houston, I can give you a reduced rate without shipping.
    Transmission/front cat plate
    The steel plates come with all hardware to install
    Bare steel
    1/8 $275
    3/16 $350
    Powder coated black
    1/8 $325
    3/16 $400
    Aluminum is bare metal but comes with the hardware to install
    3/16 $350
    1/4 $400
    Transfer case/rear cat plate
    Bare steel
    1/8 steel $225
    3/16 steel $275
    Powder coated black
    1/8 steel $275
    3/16 steel $350
    3/16 aluminum $300
    1/4” aluminum $350
    The front skid plate is almost ready for production
    Hardware used (for seeking security hardware)
    5/8x4 (2)
    3/8x4 (2)
    1/2x1.75 (2)
    3/4x1.75 (2)
    Also requested the weights of the plates. I will fill this in more in the near future
    1/8 steel front cat plate 40 lbs
    3/16 steel front cat plate 60 lbs
    3/16 aluminum front cat plate 19 pounds
    1/4 aluminum front cat plate 30 pounds
    rear cat plate weights
    1/8 steel 22 lbs
    3/16 steel 33 lbs
    3/16 aluminum 12 lbs
    1/4 aluminum 16 lbs
  2. Mar 8, 2021 at 7:34 PM
    IndianaGeologist
    IndianaGeologist New Member
    Looks great, Tyler. Would you mind posting the weights for the plates? Also, do thieves tend to steal the front or rear or both cats?
    Thanks!
    Rica25 likes this.
  3. Mar 8, 2021 at 7:42 PM
    Classy63
    Tyler
    Cypress Texas
    I will add weights to the main post tomorrow. Thieves take what ever they can... This is the best info I have found so far, large Japanese trucks and SUV’s are a main target because the catalytic converters are worth more, the tundras and sequoias are even more of a target because we are lucky enough to have 4 instead of the normal 2
  4. Mar 8, 2021 at 8:06 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    I been talking with Tyler about using security bolts. The larger front ones are almost impossible to find without paying a fortune they are 5/8. The rear 3/8 x 4" is possible from McMaster's or other hardware stores. Just fill it with silicone in the head for full deterrence.
    If you have the TRD front skid like me, you can get security bolts for the rear crossmember area, which are smaller bolts than Tyler's and since his plate fits under the TRD, it should work well. If you use the TRD plate, you wont need to use the 5/8. I am also planning on using security bolts on the TRD instead of stock hardware so with the combination of all that, I dont think there is much more you can reasonably do.
    Just looking out Tyler, I know your swamped. Correct me if I missed anything. I will try to do an install clip with the TRD plate when I get my plates.
    Toyotoholic, avssuc, KneeYa and 6 others like this.
  5. Mar 9, 2021 at 10:15 AM
    Seaflea
    Seaflea New Member
    William
    Sent you a text. Im ready to order.
    Thanks
    Classy63[OP] likes this.
  6. Mar 9, 2021 at 10:42 AM
    bwh
    bwh New Member
    Ordered mine a few days ago - can't wait to see that ship notice or whatever arrives!
    Went with aluminum. More costly, but significantly lighter. Gets the job done without lowering my payload even further.
    If I want to crawl - I've got my CJ for that.
    AircareTundra and Classy63[OP] like this.
  7. Mar 9, 2021 at 10:56 AM
    Elduder
    Elduder New Member
    @Classy63
    Can we get some pictures of the skids not mounted?
    Jackson Smith likes this.
  8. Mar 9, 2021 at 11:03 AM
    Classy63
    Tyler
    Cypress Texas
    As requested
  9. Mar 9, 2021 at 11:43 AM
    Djone27
    Djone27 New Member
    2017 MGM Crewmax TSS 4x4
    HID Headlights, full LEDs, TRD front and rear sway bars, CB +2s, Eibach Stage 2s, SABM w/ pro intake tube
    Do you know how well your skids pair up with the front RCI skid?
    typerlegend and Occidentalis like this.
  10. Mar 9, 2021 at 11:46 AM
    Classy63
    Tyler
    Cypress Texas
    This is a common question, and I don’t have an answer, I would need to know where the RCI bolts up
  11. Mar 9, 2021 at 11:56 AM
    fbingha
    fbingha New Member
    Bakersfield, CA
    Can we get a cost for the plates via PayPal without the Friends & Family request? I would like to purchase the set but I don't send F&F Paypal payments for large purchases.
    Occidentalis likes this.
  12. Mar 9, 2021 at 12:29 PM
    Classy63
    Tyler
    Cypress Texas
    Of course, I charge a 3% fee to offset the PayPal fees
  13. Mar 9, 2021 at 12:31 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I have the RCI skids on my truck and would be interested in adding cat protection. If you ever make it up near DFW, let me know and you’re welcome to measure whatever you want on the truck.
    Saltyhero13 and Mwray8909 like this.
  14. Mar 9, 2021 at 12:34 PM
    Classy63
    Tyler
    Cypress Texas
    If there is anyway someone could send me pictures of where the RCI skid plate meets the cross member between the oil pan and the transmission pan to show which holes are used, I could answer this question pretty quickly
    ColoradoTJ likes this.
  15. Mar 9, 2021 at 1:03 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    How are the rear transfer case plates attached? It looks like just the two slots that appear to go between the main cat plate and the second crossmember.
  16. Mar 9, 2021 at 1:05 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    There is a horizontal bracket that connects to the frame rails. You can see it in the 3rd pic from the top in OPs original post.
    Terndrerrr likes this.
  17. Mar 9, 2021 at 1:09 PM
    Squatting Pigeon
    Holden
    North Texas
    These are the only photos on their install guide
  18. Mar 9, 2021 at 1:10 PM
    Hope this helps.
    058EAD4B-1CE5-49A2-82A5-63EBF5CB05D9.jpg 60463A66-42E6-4C6F-BCED-034F0DA56C6E.jpg
  19. Mar 9, 2021 at 1:29 PM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    6 inch Pro Comp lift. OME rear springs with Coach Builder +3 shackles. Coach Builder tie rod ends. ICON 2.5 front and rear shocks with remote res. ICON Hyd bump stops. 35" Nitto Trail Grapplers on 18" fuel rims. Kenwood DNX 892 head unit with JL audio and RF amp pushing 2 Image Dynamics idq10 subs. SABM, S POD switches for 42" in bumper and 32" behind grille LED light bars. Full interior and exterior LED conversion. LED flush mount back up lights in rear bumper. Valentine one radar detector. V Leds under dash and seats foot well lighting. TRD pro head lights and grille. Full AJT dash kit
    For you all that have the ProComp lift and are in question of purchasing one, I ordered mine last week, 3/16 aluminum, when it gets here I will post some pictures of the install. Classy63 says it is a direct bolt on.
    JAMES and November Sun like this.
  20. Mar 9, 2021 at 1:37 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Just my opinion I have done a lot of mods over the years on my Tacoma and now my 4runner and soon to be my Tundra. What really helped me was watching all these YouTube video installs. Hopefully someone will post the install to the front and rear.
  21. Mar 9, 2021 at 1:38 PM
    Tyler, same price for red powder coating?
    tightywhitey and ColoradoTJ like this.
  22. Mar 9, 2021 at 4:10 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    Another option for people looking for extra security, since its hard to find good security bolts, is to use a standard bolt, but use a breakaway nut.
  23. Mar 9, 2021 at 4:18 PM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    Till you need to take it off to grease the front drive line U-Joints, then what?
    blizz86 likes this.
  24. Mar 9, 2021 at 4:23 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    It is just an option. You can still take them apart its just harder and longer.
  25. Mar 9, 2021 at 4:28 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    I ordered an aluminum shield for my Pro Comp as well. Hopefully it will be ready soon.
    JAMES likes this.
  26. Mar 9, 2021 at 4:59 PM
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    X2
    Is the front cat plate the main one to get?
  27. Mar 9, 2021 at 5:27 PM
    Classy63
    Tyler
    Cypress Texas
    There is an additional charge for color, it depends on the color though
    DjSamthrax likes this.
  28. Mar 9, 2021 at 5:27 PM
    Classy63
    Tyler
    Cypress Texas
    Yes, it is the meat and potatoes of the system
  29. Mar 9, 2021 at 5:30 PM
    tightywhitey
    New Orleans, LA
    You had me at meat and potatoes. How do I order?
    avssuc and Saltyhero13 like this.
  30. Mar 9, 2021 at 5:30 PM
    Classy63
    Tyler
    Cypress Texas
    Actually, if you could get me a measurement between the bolts that go in between the front skid and the transmission skid. I could compare that to my plate and have a solid answer
Thread Status:
