V8 Coolant Hose List with Part Numbers and Parts Website
Discussion in '1st Gen Tundras (2000-2006)' started by 2ndGenToyotaFan, Aug 23, 2025 at 10:17 PM.
  1. Aug 23, 2025 at 10:17 PM
    2ndGenToyotaFan
    2ndGenToyotaFan [OP] New Member
    Jerod
    2004 DC
    Just fixing the PO stuff for now…
    A little while ago, I replaced all the coolant hoses on my truck. I thought this might come in handy for some of you guys. Prices are what I found online, but I ordered through my local dealer which was around $350 I think.
    I use this website for looking up part numbers: https://www.japan-parts.eu/toyota/us
    if you’re tackling this, start with the hose that goes backwards from the oil cooler and over to the engine block. I had to remove the dip stick which was its own fiasco. Once you get that one done, everything else is gravy. Enjoy!
    2004 Tundra Double Cab, 2UZ/A340F, Build Date 03/04, Frame Code UCK41L PRSSKA
    One each:
    Upper Rad: 16571-0F020 $22.84
    Lower Rad: 16572-0F010 $34.14
    HOSE, HEATER WATER, INLET A: 87245-0C040 $49.21
    HOSE, HEATER WATER, OUTLET A: 87245-0C050 $47.01
    HOSE, HEATER WATER, INLET E: 87245-0C010 $60.43
    Oil Cooler Hose: 15777-50060 $20.23
    Hose, Water By-Pass: 16261-50090 $7.57
    Hose, Water By-Pass #4: 16281-0F010 $8.60
    Hose, Water By-Pass #5: 16282-0F010 $8.60
    Hose, Water By-Pass #7: 16295-50070 $7.57
    Hose, Water By-Pass #8: 16296-50030 $8.78
    Thermostat: 90916-03100 $24.03
    Thermostat Gasket: 16346-50010 $5.53
    shifty`, TnPlowboy and w666 like this.
