V6 Triton blinkers issue w/NSV & OEM LED headlight upgrade
Discussion in 'Lighting' started by Sas, Apr 12, 2019.
  1. Apr 12, 2019 at 2:56 PM
    Sas
    Sas [OP] Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Okay, I thought someone had already gone thru this, but I've been searching for the past hour or so and can't seem to find it.
    I used to have the old 2017 halogen headlights w/o the DRL's. I upgraded to the 2018 LED headlights and also installed the NSV bar. I ended out upgrading the blinkers to Headlight Revolution's LED blinkers, but one of them went out. So I bought the V6 Triton's from VLEDS to see if they were any brighter.
    However, I'm having some weird issues with how they're actually functioning. I had to make a video explaining it. BTW, it doesn't matter if the pink and purple wires are switched, the behavior is the same. Also, if I flat out leave the purple wire unplugged (from the middle slot), the blinkers don't work at all.
    Anyone remember how this one got fixed (assuming it has)? @iHacker @boardude @BlueBottle
    I'm waiting to hear back from VLEDS about it as well.
  2. Apr 12, 2019 at 3:09 PM
    Sas
    OKC, OK
    Well, that was fast. VLEDS got back and suggested pink/white/purple. Voila! All good now.
    Pudge likes this.
  3. Apr 12, 2019 at 3:58 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Glad you figured it out quick.
    I’m running 3156CK vled tritons. Since I am using the 3156 specific bulb there was no reason for me to repin my signals. I’m pretty sure that was your problem.
  4. Apr 12, 2019 at 5:05 PM
    Sas
    OKC, OK
    Thanks, yeah same here now. I had to repin from the HR's since they were running the 7440's. Since these V6's can use the original adapters I had to switch the pins back and just forgot what I had done lol.
    BlueBottle[QUOTED] likes this.
  5. Apr 12, 2019 at 6:32 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    AR
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Yes that’s the stock configuration so you probably have the old kind of bulb 3157CK and don’t have to switch pins
    Sorry for the delay, glad you figured out the problem
    Sas[QUOTED][OP] likes this.
