Using a spring compressor to put 2.5" leveling puck in Tundra
Discussion in 'New Member Introductions' started by coltthecoonhound, Jan 7, 2021.
  1. Jan 7, 2021 at 7:28 AM
    coltthecoonhound
    coltthecoonhound [OP] New Member
    Bill
    2021 Toyota Tundra
    2021 TRD
    Hello,
    I have a 2021 Tundra and want to add a 2.5" leveling kit, puck, on top of strut. Rather than go to all the rigmarole of suspension removals, I bought a higher end spring compressor (the one that comes in the red box, HD with keeper). My thought is to remove the wheel, suspend truck and recompress with floor jack to compress strut, attach spring compressor, un-attach strut from top housing, suspend truck then proceed to lowering jack under suspension and drop top of strut out of housing and sneak/bolt in puck, push back into place re-asserting strut into housing, reattach and done???? Remove spring compressor then get re-alignment of course.
    ***Has anyone actually done this, please?
  2. Jan 7, 2021 at 7:29 AM
    Kanobi13
    Kanobi13 New Member
    Boom!
    Medic343 likes this.
  3. Jan 7, 2021 at 7:37 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    I think i saw this done on youtube somewhere. IIRC, it was a 2 man job and there was a crowbar involved.
    Also, ask a mod to move this to the suspension sub forum
  4. Jan 7, 2021 at 7:38 AM
    CaptainGrumpus
    Maine
    The spring compressor should keep this from happening but who knows.
  5. Jan 7, 2021 at 7:42 AM
    Kanobi13
    Kanobi13 New Member
    Lol meant boom as he gots it
  6. Jan 7, 2021 at 8:08 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  7. Jan 7, 2021 at 8:18 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Also welcome
  8. Jan 7, 2021 at 2:17 PM
    coltthecoonhound
    Bill
    2021 Toyota Tundra
    2021 TRD
    Thank you all for the warm welcomes. I'm still trying to figure out the leveling kit thing?
  9. Jan 7, 2021 at 6:07 PM
    Welcome from Ohio
  10. Jan 7, 2021 at 6:44 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    Good luck. I tried that on a '87 Chevy and it didn't work.
    It's a brand new truck...just unbolt the lower ball joint and drop the strut.
  11. Jan 7, 2021 at 6:47 PM
    SouthWestGA
    SouthWestGA New Member
    https://www.tundras.com/threads/putting-in-leveling-kit-using-spring-compressor-the-easy-way.81111/
    Here’s your other thread on this topic. I’ll paste my response below
    Please don’t do it. Don’t be that guy who buys a brand new truck and a cheap $50 lift kit.
    Are you aware of the alignment issues by having a lift with the factory upper control arms?
    They are limited in range of motion. Anything over 2 inches and you take a risk that your alignment may not be able to get “in spec” and result in alignment/tire wear or handling issues. I would not want a new truck done cheap,or messed up from the beginning
    Also,it is widely known that puck lift spacers cause a crappy ride,versus a proper lift. The pucks are popular since they’re cheap.
    I’m sure experts will be along shortly
    des2mtn and CaptainGrumpus like this.
  12. Jan 8, 2021 at 4:43 AM
    CaptainGrumpus
    Maine
    Well said!
  13. Jan 8, 2021 at 5:57 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  14. Jan 8, 2021 at 6:16 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    The puck it a waste of time if others haven't already told you. Get a coil over lift. The Bilstein 5100 are decent and fairly economical if that's a thing. 6112s are a better option both have long term reliability.
  15. Jan 8, 2021 at 6:18 AM
    CaptainGrumpus
    Maine
    Unforunately, us impulse buyers cant find 6112's anywhere. Sounds like mid March before they are available again.
  16. Jan 8, 2021 at 6:22 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    I completely understand. I bought the pucks, then the 5100s, Then the 6112s.....all on impulse....:anonymous:
  17. Jan 9, 2021 at 8:52 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from the wet side of WA.
