Using a Pressure washer
Discussion in '2.5 Gen Tundras (2014-2021)' started by kcaustin66, Aug 24, 2019.
  1. Aug 24, 2019 at 10:51 PM
    kcaustin66
    kcaustin66 [OP] New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    Is a 2800 psi safe to use on my Tundra for the paint. Today I got a Craftsman 2800 psi 2.3 GPM. If so what color tip should I use.
    Also I got a foam cannon looking forward to using it my next day off. 8EB51895-1E3D-419F-A71A-19E2CF1ABDEF.jpg
  2. Aug 24, 2019 at 11:12 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    I been using a Ryobi 3000 PSI 2.3 GPM in the 40° setting for 1 year without any problems just make sure to take a good distance, I also added a pressure flow control to the wand to reduce the PSI if needed, I’m using a foam cannon and love it how the truck looks after a deep cleaning.
    Pressure Washer Flow Control Valve
    https://www.homedepot.com/p/300710839
    My foam cannon
    MATCC Foam Cannon II Foam Nozzle Pressure Washer Jet Wash with 1/4" Quick Connector Foam Blaster 0.22 Gallon Bottle Improved Snow Foam Lance https://www.amazon.com/dp/B07G2R2RVN/ref=cm_sw_r_cp_api_i_6pVyDb9B9X93E
    Bigboitundra, Pudge and JH5370 like this.
  3. Aug 25, 2019 at 12:03 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    look for a fan one, try not to get too close
  4. Aug 25, 2019 at 1:01 AM
    Trunk Monkey
    Trunk Monkey Truck's
    Steph
    2019 Tundra TRD PRO - VooDoo Blue
    Retrax One MX, NFab Predator Pro steps, Husky X-Contour mats
    40 degree white tip nozzle. If you can put your hand 15 inches away and it doesn't hurt then its safe for your paint.
  5. Aug 25, 2019 at 4:45 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I have been using a pressure washer on my trucks for many years and never had an issue. During rain season when I go on construction sites and know if will get dirty again the next day anyway, I just use the pressure washer to spray off the heavy mud so it doesn't cake on too thick; I don't even do a full wash.
  6. Aug 25, 2019 at 8:12 AM
    kcaustin66
    kevin
    I just ordered it on eBay for $18 thanks for the info (peace of mind goes a long way)
    Pudge likes this.
  7. Aug 25, 2019 at 8:22 AM
    groverdill
    groverdill New Member
    joe
    Rathdrum ID
    Foam cannons are fun! I finally got one and used it for the 1st time yesterday.
    It was awesome. Would have done the daughters Matrix but she was at work.
  8. Aug 25, 2019 at 8:40 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    nice vett what trim is that
    Bigboitundra likes this.
  9. Aug 25, 2019 at 8:45 AM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I have this same pressure washer. It works great. Which foam cannon are you using?
  10. Aug 25, 2019 at 9:42 AM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Got for it. It's super helpful, but use common sense where you pressure wash. Like don't get inches away from your door seals :thumbsup:
    TheBeast and Winning8 like this.
  11. Aug 25, 2019 at 10:41 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    I would be very cautious using this testing method!!!
    Outbound likes this.
  12. Aug 25, 2019 at 11:21 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    yup, I got a small 1800 psi washer. i try to wash my hand and got small cut from it. I was about a foot from the tip too.
  13. Aug 25, 2019 at 11:47 AM
    War Machine
    War Machine SSEM # 5 3MW
    That’s why he’s telling someone else to test it.
  14. Aug 25, 2019 at 11:53 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I've got a commercial grade 3800 psi unit here at the house. Maybe I'll test it.............on the neighbors F150!!!!!! :devil::devil::devil:
  15. Aug 25, 2019 at 11:54 AM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    UMMM Take this advice. I was 12/13 when my parents had me power wash the deck. Not sure what PSI it was but it was a gas Honda and well I though it would be a great idea to power wash my shoes. Well you can imagine how close that tip was to my shoe when I happened to clip the outside of my ankle. Instantly sliced open a nice flap of skin. 6 hours in the ER and 9 stitches later I was all good. Shit still terrifies me haha
  16. Aug 25, 2019 at 12:05 PM
    Trunk Monkey
    Steph
    With a 40 degree nozzle no problem as long as its 1000 to 1200 PSI which is great for washing cars and very safe for the paint. Above that then yes it can be dangerous. I wouldn't do it with a 0 degree or 15 degree nozzle, pumping 1800 PSI lol.
    Winning8[QUOTED] likes this.
  17. Aug 25, 2019 at 12:42 PM
    panicman
    Eric
    I commented because my brother was helping a friend clean a deck. The friend was wearing flip flops and decided to “check” the pressure on his exposed foot.
    The “testing method” resulted in a clean (but bloody) incision across all of his toes, which were nearly de-gloved.
    Many stitches, much pain. I always think about that when I fire up the PW.
  18. Aug 25, 2019 at 1:38 PM
    Trunk Monkey
    Steph
    Ouch no kidding, probably not the smartest thing to do.
  19. Aug 25, 2019 at 1:43 PM
    biebs96
    PA
    Anyone ever try the matching ryobi foam cannon that Home Depot sells along side the power washers in the aisle. It has mixed reviews online.
  20. Aug 25, 2019 at 1:49 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    I’m using one of the cheap ones off Amazon and worth the money paid for it
    War Machine and JH5370[QUOTED] like this.
  21. Aug 25, 2019 at 1:57 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    I have that one too, is nice but I do not recommend it for our trucks, the soap reservoir is extremely small and when I used it I have to fill it up 2-3 times
    Pressure Washer Foam Blaster
    https://www.homedepot.com/p/300701619
  22. Aug 25, 2019 at 2:11 PM
    biebs96
    PA
    That could not have been more of a helpful answer.
    Having to stop a few times kind of defeats the purpose.
    What cannon are you using?
  23. Aug 25, 2019 at 2:58 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    I’m using this one
    $25 MATCC Foam Cannon II Foam Nozzle Pressure Washer Jet Wash with 1/4" Quick Connector Foam Blaster 0.22 Gallon Bottle Improved Snow Foam Lance
    War Machine and JH5370 like this.
  24. Aug 25, 2019 at 4:11 PM
    GeoJoe
    GeoJoe 2018 Tundra SR 4x4 5.7L Looooooooong Bed
    3/1 lift on 20" OZs with KOs, LED fogs, steps and a handle
    I use a similar one cannon on a 2800 psi pump. Works great... and the foam juice is this stuff: https://www.chemicalguys.com/honeydew-snow-foam/honeydew-snow-foam.html
    plumber802 and iHacker[QUOTED] like this.
  25. Aug 26, 2019 at 5:33 AM
    Boerseun
    Ferdie
    Sarasota Florida
    Unfortunately we live in a world where common sense do not exist any more. And I admit I have done a few stupid things in my life. However, I do use the pressure washer to spray off my feet and lower legs when there is splattered debris all over me. The 'secret' is just to start far away and move it closer until it does the job without hurting you. Don't start up close and move it away if it hurts - that might be too late.
    The same principle for washing the truck, start far away and move a little closer to get the stubborn bugs or mud cakes off. Keep in mind the truck cannot feel it, so you have to 'feel' with your common sense.
    I have been washing my trucks with pressure washers for years and never had any issues.
  26. Aug 30, 2019 at 6:45 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    I read this thread and thought, what the heck, and decided to order the above foam rig to give it a try. About a month ago I bought a gallon of MR Pink super suds shampoo and though I would see how the two would work together.
    Tonight I washed the truck. I set up the container with hot water first and soap at a 1/4 ratio.
    I was thinking, based upon some of the posts, that I might try to use up only a bottle of the mixture for the entire truck.
    Dang! This thing is the BOMB. I swear I covered the entire truck, stem to stern, wheels wheel wells 3x at least three times. I washed it once, refoamed and went over it by hand and then foamed it again for a repeat.
    I was looking at the foam supply bottle and the amount of mixture I had to us was ridiculously small! I could have washed a fleet of tundras.
    Here is a shot of the first layer and the remaining mixture after I gave up in the thought of using it all. I just pulled and cleaned the nozzle and will capped the reservoir. Will see what it looks like next time.
    DBF4517B-D1ED-451E-B2FE-F22954531F15.jpg DD931EFC-EE82-4211-B4BE-743E23A767F6.jpg 3225E8CA-D9A6-44E6-B9AE-D880549DBC47.jpg
  27. Aug 30, 2019 at 7:00 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    This is a helpful thread , i was planning on getting a pressure washer for BF, my wife just told me to wait.
  28. Aug 30, 2019 at 7:22 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    Just to make sure about my post. I didn’t mention the pressure washer. I have a small electric 1700 psi pressure washer this connects with. It won’t work off a hose alone. The foamer runs about 24$ but you need a Pressure Washer at 1000 psi to use it.
    Ely010606[QUOTED] likes this.
  29. Aug 30, 2019 at 9:28 PM
    Ely010606
    SPARKS, NV
    Thanks , that’s what im gonna wait for is for the pressure washer.
  30. Sep 2, 2019 at 8:07 AM
    flynbyu2
    flynbyu2 I'm your huckleberry...
    NorCal
    2015 SR5 CrewMax 2WD
    Flowmaster Super 50 / Dual In - Dual Out Exhaust BakFlipG2 Tonneau Cover TRD Rear Sway Bar
    Adams has the best foaming car wash I’ve run across so far.
    It’s called a Mega Foam and it’s on sale right now.
    https://adamspolishes.com/products/adams-mega-foam
    The foam is as thick as shaving cream when it comes out and it sticks on the vertical surfaces nicely.
