Used trailers?
Discussion in 'Towing & Hauling' started by AlmightyCrash, Apr 10, 2019.
  1. Apr 10, 2019 at 10:16 AM
    AlmightyCrash
    AlmightyCrash [OP] Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    ive never had a trailer, and need one for my side by side. I don’t have much money, so I am looking at used trailers. I was hoping to get some advice about things to inspect or look for so I don’t get a bad one. Any help is appreciated.
    Thank you.
  2. Apr 10, 2019 at 10:27 AM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Wheel bearings are the big one. Often neglected. Jack it up and make sure the wheels spin smooth. Open the dust cap and check for clean grease. Not a deal breaker if it needs new bearings, but definitely a negotiation point. They are inexpensive and fairly easy to replace. Check the trailer wiring to make sure the lights work. Again easy fix, and lights are cheap, but a negotiation point as well if they don't work. Check date codes on the tires. Those are always neglected because the tread never wears and they just crack from age.
    Other than that, just obvious signs of damage to the steel. I assume youre looking for a single axle with no brakes, otherwise theres some other things to look for with the brakes.
  3. Apr 10, 2019 at 11:05 AM
    SnowroxKT
    SnowroxKT New Member
    Kyle
    Alaska
    Bad wheel bearings, non-functioning lights, and bent tongues are the most common things I see with older trailers.
