Used 4x4: similar mileage and price, would you chose 1st or 2nd gen Tundra or Tacoma?!!
Discussion in 'General Tundra Discussion' started by Sunnier, Feb 1, 2018.
  1. Feb 1, 2018 at 5:17 PM
    Sunnier
    Sunnier [OP] Pity the warrior that slays all his foes
    Sunny
    San Diego, CA
    I'm thinkin' about keepin' the one I have for lookin' pretty, and gettin' another to do dumb tricks in. What'd'ya think about my options, and what should I look out for, with each?
    I know to look for cam leaks and rust, and have a buddy lined up to go with me to look.
    eccracer104 and blue16 like this.
  2. Feb 1, 2018 at 5:26 PM
    Marty McFly
    Morty McBoonJug
    What! No moe inferno in the desert :annoyed:
    If it's strictly for wheelin, I'd go Tacoma. You can fit in some tiny trails us tundras can't go through :(
  3. Feb 1, 2018 at 5:33 PM
    Woodguy65
    Woodguy65 New Member
    Yeah agree no question if just going off road Taco rules. Whats your budget - First generation Tacoma with TRD package great vehicle.
    Sunnier[OP] likes this.
  4. Feb 1, 2018 at 5:56 PM
    Sunnier
    Sunny
    San Diego, CA
    I can't part with the BFT unless I find a very low mileage exact same configuration + 4WD, which is a very rare unicorn. So now I'm thinking a cheaper solution would be a separately play truck.
    Super cheap. I'll look for that. Thanks!
    Marty McFly[QUOTED] likes this.
  5. Feb 1, 2018 at 6:06 PM
    Those 1st gen Tundras are pretty spry off the road. Not much different in size to the Taco and you have a real decent V-8 to play with.
  6. Feb 1, 2018 at 6:21 PM
    I would vote 1st gen Tacoma TRD.
    Smaller, lighter, e-locker that can be modified to work in 4hi or 2wd, cheaper to maintain, better fuel economy.
  7. Feb 1, 2018 at 6:26 PM
    Sunnier
    Sunny
    San Diego, CA
    That's what I was thinkin'. Plus I can still claim "Tundra" at the SoCal meets.
  8. Feb 1, 2018 at 6:28 PM
    Sunnier
    Sunny
    San Diego, CA
    Modified? You mean 4x4, or TRD with locker, modified somehow?
  9. Feb 1, 2018 at 7:04 PM
    On the first gen Taco, at least with the standard transmission, you could splice together the 4wd signal and it would trick the transmission into thinking it was in 4lo. This is what would release the rear differential to use in 4lo/hi/2wd, and at any speed after engagement. The 4wd light still worked as factory. Total win.
    The automatics had a few more things to do if I remember correctly to get this accomplished. I just can’t remember, this was 18 years ago.
  10. Feb 1, 2018 at 7:40 PM
    Sunnier
    Sunny
    San Diego, CA
    Sorry. I gotta admit, I still don't understand. Do you mean, I can find a 1st gen Taco 2WD TRD with the locker, and trick it into thinking it has lo/ hi? Or am I looking for a 1st gen 4x4 TRD?
    Sorry to keep asking, Chris. I rely on your good advice, and appreciate it in this case. There's a coople options I plan to check out tomorrow; if I can sort out what you mean, I'll likely make a better choice.
  11. Feb 1, 2018 at 7:52 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    If you want a bad ass, off road capable Toyota, look at the v8 4runners. For me I don't have a need for 2 pickup trucks, so if I wanted a "modern" Toyota off roader, id get a v8 runner for sure.
    If I had to choose between what you asked lol, I'd get the taco as a trail or off road rig
  12. Feb 1, 2018 at 7:53 PM
    No problem sunnier.
    So you are looking for a 4wd truck, so I assume that is what you’re getting. Not a 2wd only truck.
    So the locker is in the rear differential, and makes it a true solid drive. Both wheels will turn at the same speed, no matter what. From the factory, this option can only be operated in 4lo with the transfer case. With the modification, you can operate this locker in any situation, which could be in 4Hi or even in 2wd.
    Does this help?
  13. Feb 1, 2018 at 8:41 PM
    Sunnier
    Sunny
    San Diego, CA
    Yes! I'm looking for a 4x4, and if I can find a manual 1st gen Taco, it may be made more awesomer! Got it!!
    Thanks, Chris!!
  14. Feb 1, 2018 at 9:17 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Not one of the options you mentioned but what about Land Cruiser 100 series?
    Sunnier[OP] and Y0TA PR0 like this.
  15. Feb 1, 2018 at 9:29 PM
    TheBeast The Beach
    or even an older Lexus SUV
  16. Feb 1, 2018 at 10:37 PM
    Gtfour43
    Gtfour43 New Member
    Oahu
    GX470?
  17. Feb 2, 2018 at 9:00 AM
    Sunnier
    Sunny
    San Diego, CA
    Y'all are giving me great ideas!
    (Too many :annoyed:)
    I did realize, last night, that if I get something with a proper back seat, we'd get more on-road use if it. We're a family of 3 so trucks work, but we host visitors pretty frequently. It makes sense to get something that could be a carrier in those situations, so we can let the :anonymous:
    Chevy Cobalt go next time it wants to cost us money.
    But, dang, there's a bunch 1st and 2nd gen Toyota 4x4 trucks near me, in the $3500 - $4000 range. I'd have to spend actual money for one of these other options. Hhmmm....
  18. Feb 2, 2018 at 9:15 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Tacoma double-cab, GX, or 4Runner.
    Hold out for one with the rear E-locker.
    The 3.4 V6 is possibly one of the most reliable, easy to work on, bulletproof engines ever made. It is non-interference, if the timing belt breaks it will not be catastrophic, this gives me a lot of confidence when looking at higher mileage Tacomas or 4runners.
  19. Feb 2, 2018 at 9:35 AM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    What about a 1st or 2nd generation 4Runner? :anonymous: Avoiding the 3.0 of course. And the automatic. 22re/w56 combo is arguably the most reliable combo known to man. The older torsion bar suspension is more rugged in stock form. 2nd gens have 4-doors and a tailgate! In my area 3.0L 2nd Gens are so cheap, you can't give them away! Nice ones too. :confused:
    Fierceblues and Sunnier[OP] like this.
  20. Feb 2, 2018 at 9:47 AM
    Sunnier
    Sunny
    San Diego, CA
    What does this mean? "22re/w56 combo".
    And would you say no to a 3rd gen, automatic, not a 3.0? If so, why?
  21. Feb 2, 2018 at 9:59 AM
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    ^ "Locker Anytime Mod" or also called "Grey Wire Mod"
    4x4 TRD Off Road Tacomas (auto or manual) (1st gen, 2nd gen and 3rd gen) come with the factory e-locker, but it can only be engaged when in 4-Lo. With the grey wire mod you can use your locker in 2wd, 4Hi and 4Lo which is a nice advantage to have!
    Sunnier[QUOTED][OP] likes this.
  22. Feb 2, 2018 at 10:05 AM
    Sunnier
    Sunny
    San Diego, CA
    Can this "Grey Wire Anytime Locker Mod" be done on 1st - 3rd gens or just 1st gen?
  23. Feb 2, 2018 at 10:08 AM
    BHarry
    BHarry New Member
    Northern Nevada
    2014 BRM CM TRD
    22R-E was an engine used in some Toyota vehicles from the mid 80's through the mid 90's and W56 is a transmission used in the same time frame.
  24. Feb 2, 2018 at 10:13 AM
    eccracer104
    San Diego, CA
    1st gen, 2nd gen and 3rd gens :thumbsup: Works for auto and manual transmissions as well.
  25. May 20, 2023 at 11:45 AM
    Fierceblues
    Fierceblues New Member
    Jeff
    2007 Silver Tundra DC 4X4 5.7 six passenger
    ARES Overland Topper, JBL system, sonar, tow package, Tow mirrors, transmission cooler and factory bedliner w/rails.
    I know older thread....being new to this forum I had to chime in about 2nd Gen 4runner 4x4 with a 22RE. I am the original owner of a 91 with the 22re and it has been nothing but solid, plus much more off-road friendly than the mighty Tundra in tight trails and off trail brush busting.
    BillyB likes this.
  26. May 20, 2023 at 4:23 PM
    Sunnier
    Sunny
    San Diego, CA
    How this turned out:
    First I got a 2001 4 Runner, 4x4 with "locker", but that wasn't all that. So it became my honey's daily driver, and I bought a 2001 Tundra... which has long travel and kicks ass... or flies!
    Later upgraded the suspension in the 4R so it's a lot more capable as well.
    PermaFrostTRD, Fierceblues and Mr.bee like this.
  27. May 20, 2023 at 9:08 PM
    Fierceblues
    Jeff
    Sounds like you finally got what suits you.....have a good one.
