Used 2019 Tundra w/ P1613 Code
Discussion in '2.5 Gen Tundras (2014-2021)' started by TXLM35, Apr 6, 2022.
  1. Apr 6, 2022 at 9:34 AM
    TXLM35
    TXLM35 [OP] New Member
    Hey yall,
    I've been scouring the internet for a new (to me) tundra. Finally found one with low milage, 1 owner, and all my needs plus some. It's a 2019 limited with TRD OR pkg 17k miles. Contacted the dealer and he shot me straight saying it popped a check engine light reading P1613 which is the "secondary air injection system driver" per google. I know they recently changed the battery as well.
    I've only seen one other post on here with that error code on a 2.5 gen but it involved someone's cat converter getting stolen off their truck and the code popping after the replacement cat was installed...
    Very clean looking truck but if this is a plaguing issue I want no part of it...this is why I'm ditching my Ford and returning to Toyota.
    Anyone have any input? Thanks in advance.
  2. Apr 6, 2022 at 10:08 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Under warranty, have the dealer fix it.
    Saltyhero13, shawn474 and Mater like this.
  3. Apr 7, 2022 at 6:16 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    SAIS is one of Toyota’s bonehead engineering devices. It’s located under the intake so expensive to fix. There are kits to bypass as long as your state doesn’t have smog inspections
  4. Apr 7, 2022 at 6:41 PM
    Haven't seen a lot of failures on the AIP system on this new of a truck.
  5. Apr 7, 2022 at 6:52 PM
    timsp8
    NY
    Check for water damage. I’ve read the AIP system can suck up water if it’s deep enough and damage it. Might be why the previous owner got rid of the truck.
    FireMedic35 likes this.
  6. Sep 28, 2022 at 10:51 AM
    HewittTech01
    HewittTech01 Dont Replace SAIS, Bypass It!
    Lexington, SC
    Secondary Air Injection System Bypass Kit
    @batman900 I hope you were able to track down the issues. The P1613 is not all that common but very specific error code, it relates to the Air Injection Drivers in the Secondary Air Injection System. When we come across this error code we recommend doing some troubleshooting. You hope the driver has gone bad which is a simple fix (not particularly cheap) you can replace it. Again, it is not common for the drivers to go bad especially on a vehicle as new as 2019. as @timsp8 mentioned the more likely reason for the error code is some time of water or wiring damage. This is much more intensive to track down. I hope this helps and for additional resources on the SAIS check our the thread below.
    What Does the Secondary Air Injection System Do?
    https://www.tundras.com/threads/what-does-the-secondary-air-injection-system-do.113683/
    What Do My Secondary Air Injection Error Codes Mean?
    https://www.tundras.com/threads/what-do-my-secondary-air-injection-error-codes-mean.113686/
    How to Fix Secondary Air Injection System?
    https://www.tundras.com/threads/how-do-you-fix-the-secondary-air-injection-system.113688/
    timsp8 likes this.
