Use standard CVs?
Discussion in 'Suspension' started by AusDiver, Nov 8, 2019.
  1. Nov 8, 2019 at 12:14 PM
    AusDiver
    AusDiver [OP] New Member
    06 Double cab, black
    2” lift
    Hi, I bought my (06) truck a couple of years ago, it was supposed to have the lift kit installed at the car yard( it wasnt) so I fitted it when I got it home. I dont do a lot of off road so dont use 4wd much, but when I do the CVs are really noisy, I know they need replacing but, my question is will standard CVs be ok or do I need to get longer ones ? Thanks in advance
  2. Nov 8, 2019 at 12:28 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Did you do diff drop? If you haven't that might be your problem
    MS22 likes this.
  3. Nov 8, 2019 at 12:30 PM
    AusDiver
    2” lift
    Blocks in rear and rings on the struts on front
  4. Nov 8, 2019 at 12:36 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    You have to do differential drop, your CV axles are on steep angle and that's what wearing them out. Diff drop with standard CV axles should cost less as well
    AusDiver[OP] and MS22 like this.
  5. Nov 8, 2019 at 12:49 PM
    AusDiver
    2” lift
    Ok thanks, I havnt heard of dropping the front drive train on independent suspension. I will look into it
  6. Nov 8, 2019 at 12:57 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    No problem. You can get that kit for around 30 bucks off Amazon
  7. Nov 8, 2019 at 1:02 PM
    AusDiver
    2” lift
    I will look it up. Cheers
  8. Nov 8, 2019 at 1:28 PM
    AusDiver
    2” lift
    Thanks for your help Bud, found and ordered them. Cheers
    14CRWMX likes this.
  9. Nov 9, 2019 at 12:07 AM
    AusDiver
    2” lift
    Cheers, not many guys know Tundra downunder, its even worse where I live, there is 5 in my state. I hope I never need a heap of parts.
    Migraine likes this.
