Use of Cradles with Airbags
Discussion in '2.5 Gen Tundras (2014-2021)' started by NY98M3, Jul 22, 2020.
  1. Jul 22, 2020 at 6:59 AM
    NY98M3
    NY98M3 [OP] New Member
    Gents,
    Last year I installed a set of Firestone Airbags in the rear of my 2017 Crewmaxx. I installed them to help carry the load and even the truck out a bit while towing.
    While I was there I installed Daystar Cradles thinking that I didnt want the dealer to full droop the suspension and messing up the airbags.
    My truck does NOT have any suspension mods in the rear. It seams the airbag is short and fat when not in use.
    Should I remove the daystar cradles and let the airbags attach to the rear mount for the airbags like they are supposed to?
    Looking for some advice.
  2. Jul 22, 2020 at 7:03 AM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    as long as you keep a minimum of 5 pounds in the air bags you will be fine. I have the same set up (no suspension mods and cradles with my Firestone air bags), no problems.
  3. Jul 22, 2020 at 7:11 AM
    NY98M3
    Do you find that going over bumps it bottoms out?
  4. Jul 22, 2020 at 7:16 AM
    41bigdawg
    41bigdawg Let the BIG DAWG Eat
    Robert
    Tennessee
    2013 Tundra DC 5.7
    Magnum front, Iron Cross rear bumpers, SB Cold air intake and Gibson Metal Mulisha exhaust, Fender flares, Tow mirrors, 18" Outlaw wheels, 12k Smitty X2O winch, Tech 12v auto start, Firestone Air Bags, Pedal Commander, Devil Horns, etc...
    I am not sure why you would want to do that, they are designed to work with a stock suspension. Like stated above, keep 5lbs of air in them and there should be no problem.
  5. Jul 22, 2020 at 9:27 AM
    Northbound Train
    Glenn
    Western MA
    No. Even though you have removed the bump stops the 5 psi or more in the bag will keep it from bottoming out. The thickness of the base of the cradle isn’t more than 3/4” if I remember correctly, it’s not a significant difference.
    41bigdawg likes this.
  6. Jul 26, 2020 at 5:50 AM
    Any pictures of the install?
  7. Jul 26, 2020 at 9:24 AM
    Northbound Train
    Glenn
    Western MA
    I’ll try and get some today
  8. Jul 26, 2020 at 9:31 AM
    Northbound Train
    Glenn
    Western MA
    Here are some, hopefully they came out ok.
    This is with 6 psi.
  9. Jul 26, 2020 at 9:37 AM
    Northbound Train
    Glenn
    Western MA
    Another
    Jim LE 1301 likes this.
  10. Jul 26, 2020 at 9:42 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    You have an excellent setup and can’t see an advantage in changing it.
    Northbound Train likes this.
  11. Jul 26, 2020 at 2:35 PM
    41bigdawg
    Robert
    Tennessee
    2013 Tundra DC 5.7
    That looks excellent...So what was the problem again?
  12. Jul 26, 2020 at 2:58 PM
    Northbound Train
    Glenn
    Western MA
    I wasn’t the OP, but I believe the OP thought using cradles with the bags made the bags too squished with a stock suspension.
  13. Jul 26, 2020 at 3:20 PM
    Red Freighter
    Red Freighter Red Freighter
    Oregon City
    2013 double cab sr5 trd red
    2014 TRD wheels and TRd pro center caps. Stock 2014 running boards. Stereo gps dvd deck two 12" subs w/amp. Dvd Headrests. Rear air bags with compressor and air tank.
    Let me make a guess. With the cradle the airbag is not attached at the bottom. So if your like rock crawling the axle can drop down farther.
  14. Jul 26, 2020 at 6:18 PM
    Thanks
  15. Aug 9, 2020 at 6:32 AM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Not sure if this is designed this way or not but the washer under the bolt puts the bolt further than the cradle. That means when the air bag hits the cradle it will hit the bolt. Anyone else notice this?
  16. Aug 9, 2020 at 6:41 AM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    When you aren't under load, your suspension should be more than capable of handling any bumps. When you asked about bottoming out, are you bottoming out when you don't have a load? If you are, sounds like there is something wrong with your suspension. If you are bottoming out with a load just add more air to the bags.
  17. Aug 9, 2020 at 6:45 AM
    The issue is with the hardware they provide. If you do bottom out it will put a dent in the bottom of the air bag.
  18. Aug 9, 2020 at 6:20 PM
    @Northbound Train
    Glenn, did you have this with your install?
  19. Aug 9, 2020 at 6:58 PM
    I just order hex key bolts that have a smaller head height. I could have just used the hex bolt they provided without the washer but I'd rather be safe than sorry.
  20. Aug 9, 2020 at 8:11 PM
    Nick, do you have a link or info? I plan on doing this. Thanks.
  21. Aug 9, 2020 at 8:48 PM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    They do bottom out. You only need to keep 5lbs in the bags when the bottom is attached to leafspring bracket to help fight tearing. If using cradles you are able to suck them up to gain some uptravel in the rear.
    What I do after I am done towing for a bit is right before I unhook my trailer is I let the air out of my bags. With the tongue weight compressing the rear springs it will force almost all the air out. Then when I unhook and truck goes back to normal ride height the bags are about a inch higher than the lip of the cradle. No more bottoming out around town.
    Cavalry5.7 likes this.
  22. Aug 9, 2020 at 9:04 PM
  23. Aug 9, 2020 at 10:36 PM
  24. Aug 10, 2020 at 3:24 AM
    Northbound Train
    Glenn
    Western MA
    I got my cradles on ebay, they were opened bags without hardware and were cheap. I got my own bolts and don't remember seeing this and I would have noticed if they weren't flush.
  25. Aug 10, 2020 at 4:21 AM
    DXO
    DXO New Member
    South Shore, MA
    2014 Crewmax Limited
    I just did mine this weekend, the back sits about an inch higher now with 5lb. I'm going to try putting some weight on it and getting all the air out. I noticed the same thing with the cradle mounting bolt, but it also felt like there was a recess under the sticker on the bottom of the air bag that would line up with the head of the bolt. I bought my cradles on Amazon and didn't realize that they are knock-offs until I received them. They have the same numbers stamped into them and look identical to the one Nick posted. This is my second set of bags, the first set was on there when I got the truck and somehow developed a tear in one, it had been on a lift a couple of times so that may have done it, thats mainly why I went with the cradles, cheap insurance.
  26. Aug 10, 2020 at 4:25 AM
    The bottom of the air bag is actually a thread for the bolt if you are not using cradles. With cradles, the head of the bolt will have contact with it.
  27. Aug 10, 2020 at 5:09 AM
    :thumbsup:
  28. Aug 31, 2020 at 11:17 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Installed cradles on my Tundra yesterday. I run Firestone Ride Rites. It felt like I went back to having a rake on my drive to work today. I’m running 6112/5160 and I was pretty damn level before install. They were easy to install and I like the cradles but I’m not going to like the rake. Maybe it’s placebo? I’m going to measure when I get home.
  29. Aug 31, 2020 at 11:36 AM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    So what are lifted guys using for airbag mounting ?
    I have a 1" lift block under mine, plus 2" rear shackles.
    Just curious if they make a spacer kit or taller bags ?
  30. Aug 31, 2020 at 1:14 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I'll be interested what you end up doing.
    I've thought about adding some bags in the back so if/when i put a heavy load on the truck i can level it easily.....but i dont want a crazy rough ride in the back and dont want the suspension height in the rear to change when there's nothing in the back. I'm assuming if you lower the psi then the bag will bulge and rub on the cradle?
