USB port works intermittently
Discussion in '2.5 Gen Tundras (2014-2021)' started by Fishin1981, May 18, 2017.
  1. May 18, 2017 at 4:22 AM
    Fishin1981
    Fishin1981 [OP] New Member
    2015 tundra limited crewmax
    Pop and lock, esp storage, access lorado, front tints
    My USB port under the radio seems to work when it wants. Sometimes if it's not charging my phone I turn the truck off and on and it's back to working. Any ideas why this might happen? Also, what is the "security"? Can that be removed and replaced with another switch?
  2. May 18, 2017 at 6:54 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    The USB sounds like it could be just a loose wire. As far as the Security light, I wouldn't take it out personally, but I don't see why not. If you need more switched why don't you put them on the underneath side, right above the USB and 12V?
  3. May 18, 2017 at 12:34 PM
    Fishin1981
    I'm not an electrician but a loose wire doesn't make sense. I literally turn the car off and on and then it will work.
  4. May 18, 2017 at 4:03 PM
    How bought getting some pliers in give a small light squeeze to the usb cord end??? So it makes good contact to usb port
  5. May 22, 2017 at 5:19 PM
    Steve Tundra
    Steve Tundra New Member
    Steven
    2022 4x4 platinum
    Yeah this happens to me as well. I think it has to do with over drawing power. I have to do the same thing by restarting my truck and then it works fine. Not sure what the deal is there.
  6. Oct 4, 2018 at 6:35 PM
    Tornado Bones
    Tornado Bones New Member
    2016 Tundra 4x4 5.7
    Same issue in my 2016 tundra 4x4. Power seems to have a mind of it's own. Lately, it's not working much at all. Its affecting both front cigarette lighter ports, the front usb port and the lighter port in the back seat. Fuses are fine. As many comments as I'm seeing online, Toyota must be aware there is an issue. I travel a lot internationally so I dont have time to wander over to a service department to leave my truck for a couple of weeks or wait half a day in the service dept to fix my lighter. Appreciate any advice from the rest of you on this thread!!
  7. Oct 4, 2018 at 7:02 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    have you tried a shorter usb cable?
  8. Mar 5, 2019 at 8:19 PM
    tee1000
    tee1000 New Member
    2010 Tundra Crewmax
    I have similar issues on my 2010: All 3 outlets turn off and on repeatedly no matter what is plugged in, almost like a relay every 10-ish seconds. Anyone else seen this or have updates?
  9. Mar 5, 2019 at 8:29 PM
    TomyTun
    TomyTun New Member
    CA
    2016 TRD Off Road, Crewmax, 5.7L Non-FFV
    None
    I had a similar issue using an Amazon cheapo USB cord. I fixed the problem by switching to an Apple cord. Might be worth a shot for you to try.
    15whtrd likes this.
  10. Mar 13, 2019 at 2:27 PM
    tee1000
    tee1000 New Member
    2010 Tundra Crewmax
    Thanks Ron! I was using a stock Verizon USB 3.0 cable for Android. I got some (seemingly) better quality ones from Anker and they seem better. Still happens once in a while but it's not all the time like it was with the other cable.
    Anker USB C Cable, [2-Pack 3Ft] Premium Nylon USB-C to USB-A Fast Charging Type C Cable, for Samsung Galaxy S9/ S8/ Note 8, Ipad Pro 2018, LG V20/ G5/ G6, Pixel 2 XL, and More(Black)
    Sold by: AnkerDirect
    Watt maker likes this.
  11. Mar 13, 2019 at 2:36 PM
    15whtrd
    15whtrd Mr. Blonde
    Is there a relay for the outlets or is it just a fuse? Maybe try replacing the fuse for the hell of it. If it’s a relay maybe try swapping it with another one similar. Just throwing it out there.
