USB Port not charging phone
Discussion in 'Audio & Video' started by Jota21, Nov 5, 2019.
  1. Nov 5, 2019 at 4:54 PM
    Jota21
    Jota21 [OP] New Member
    just tried to plug my phone into the USB port and nothing happened. Started the truck and it dinged like it was charging, but shortly after, realized there was no lightning bolt symbol indicating that it was being charged. After that, no matter what i did - fiddling with the connections, unplugging/replugging, etc. it wouldn't charge. Anyone run into this?? Would a USB adapter into the 12v cigarette lighter plug work??
  2. Nov 6, 2019 at 6:31 AM
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    2014 Silver Tundra SR5
    3in ToYtech lift on Tundra and 2.5in in the rear. Tow Mirrors. Toyota grill, and Front bumber. New 6in antenna. Repainted the stepping boards
    I have the same problem also. Changed the fuse and check the wires make shore nothing was loose, still docent work. If you find the answer let me know Thanks
  3. Nov 6, 2019 at 6:42 AM
    Mnorris1206
    08 tundra
    My wife's 2018 camry the usb is only for the radio to link to toyota app. Is this the same one your trying to use. Btw hers doesnt charge the phone. So she just uses the old cigarette lighter one.
  4. Nov 6, 2019 at 6:53 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Most built in USB ports only charge at 500ma which isn't enough to keep up with most phones.
    Most phone chargers now are at least 2A.
    yoshi82 likes this.
  5. Nov 6, 2019 at 7:05 AM
    GreatBigAbyss
    GreatBigAbyss New Member
    2018 Tundra CrewMAX SR5 TRD Off-Road
    I just use a cigarette lighter usb charger to charge my phone. The built-in USB charges so slowly that its practically useless.
    The advantage to the cigarette lighter charger is I can move it to the back if one of the kids needs to charge a device. #CrewMaxlife
    YsoSeRiouS! likes this.
  6. Nov 6, 2019 at 7:29 AM
    marinakorp
    marinakorp New Member
    2010 DC 5.7 SR5 TRD Mica Green
    Tow Mirrors, Tekonsha p3, 12 v Solutions remote Start,Weather Tech Mats, Truxedo Roll up Tonneau
    as others have said - the usb is barely able to charge anything...most need at least a 1.5 ma to charge - if not more....I dont use the USB at all - just BT in to my headunit.
  7. Nov 6, 2019 at 7:35 AM
    wakeboarder
    wakeboarder New Member
    13 Tundra
    My iPhone 8+ charges on my USB port, albeit very slow...
  8. Nov 7, 2019 at 7:38 PM
    kjkeats
    kjkeats New Member
    Rendon, TX
    15 CM SR5 MGM 4x4 5.7L
    I had to quit using USB and buy a cheap lighter plug adapter with charging cord. And, have to change out charging cords every 6 or so months.
    I think all the moving the phone around while it’s charging accelerates the cord wearing out faster.
    only good part is being able to use the lighter outlet inside the center console and just leave the cord hanging towards passenger seat. There when I need it, not in the way when not in use. Maybe try a different cord, or a different cord with cig lighter adapter.
    That’s what works for me, hope it helps. Good luck with your issue, bet it’s frustrating not being able to charge when you need to.
  9. Nov 7, 2019 at 8:02 PM
    Tapper
    Tapper New Member
    Durango, CO
    2015 Toyota Tundra 1794
    3 " lift, white, tan leather, snugtop, 33 bfg k2, 20 fuel rims, fab 4 front bumper, 38" Rigid double, white and black labs
    I have the same issue with my new iPhone X max. I thought that something had gone wrong with the USB ports. But they were still alive. I wound up buying a cigarette lighter USB adapter and it works like a champ.
  10. Nov 8, 2019 at 2:59 AM
    bradleykd
    bradleykd New Member
    Brad
    Kentucky
    2016 Limited-BLACK
    With IOS 13 you have to "unlock your phone to use accessories." Because it recognizes the built in USB as an accessory, you have to unlock the phone after plugging it in. Then it should start charging.
  11. Nov 16, 2019 at 2:26 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    The USB port is only meant to transfer data. It’s not supposed to charge the phone.
  12. Sep 6, 2021 at 8:34 PM
    Jsnake89
    Jsnake89 New Member
    Dane
    2019 Tundra TSS SR5 8W2
    Bilstein 5100 3/1 Pro Comp 1" Blocks, 12Volt Remote start.
    I have this issues with the cig tone inside the console and the 2 for the back seat.
