Usb option?
Discussion in '1st Gen Tundras (2000-2006)' started by Epo3412, Oct 24, 2021.
  1. Oct 24, 2021 at 9:48 PM
    Epo3412
    Epo3412 [OP] New Member
    Edward
    2001 toyota tundra sr5
    Just purchased a 2001 sr5. Wat are my radio options for usb and Bluetooth?
  2. Oct 24, 2021 at 9:58 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I usually go to Crutchfield to see what fits and is available. Both radio options are available in aftermarket.
    If you're looking for OEM, you might find those features in a later version like an 05/06. I not sure if it's a direct fit, but I believe it can be done.
    Tundra2 likes this.
  3. Oct 24, 2021 at 11:38 PM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    Need a aftermarket receiver. I like the Sony in mine
  4. Oct 24, 2021 at 11:51 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I have a 2019 Toyota 86 radio in my 05. But being an 01 it will be FAR easier and cheaper to go with a decent aftermarket unit and replace one of the power outlets with a USB port
    KNABORES and Epo3412[OP] like this.
  5. Oct 24, 2021 at 11:52 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
  6. Oct 25, 2021 at 3:49 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    I've noticed everything brand name at Crutchfield is "Temporarily Out of Stock". It seems about all they have left is Dual and Boss. I presume it's a result of the microchip shortage.
  7. Oct 25, 2021 at 4:01 AM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    12” Bulletproof Lift, AFE CAI, AFE Exhaust, rock lights, Fas-Top tonneau and soft topper, Dasaita 10.2” radio, light bar, ditch lights, LED headlights and fog lights, LED interior lights, Amp Research rear bumper step, dashcam, BT ODBII reader and Torque app on radio
    Yes, the microchip shortage is definitely having an impact in the head units. I went with the Dasaita unit and a lot had to do with availability of radios in general.
    They just received some Pioneer double din units come in a couple months ago, but out of stock on most everything else.
    Crutchfield is in my town, so I drop in every once in awhile. I’ve also gotten discounted stuff from their return department.
    Jack McCarthy likes this.
  8. Oct 25, 2021 at 5:08 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Local bestbuy installed mine for free. JVC-M750. I’ve been pretty happy with it.
  9. Oct 25, 2021 at 5:34 AM
    ezdog
    ezdog New Member
    Gateway To The West
    Every Din or Double DIN radio should fit into the 2001 truck,just find the one that you like and go with it.
  10. Oct 25, 2021 at 5:53 AM
    shifty` In South Dakota Trouble ain't hard to find
    KNABORES, alb1k and abcinv like this.
  11. Oct 25, 2021 at 11:14 AM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Depends what you're looking for. If the stock system is okay for you, then these type fm transmitters work great. I've been using one for Bluetooth streaming for music from my phone for 3 or 4 years now, also plays a mini SD card and does hands free phone calls. An amazing gadget if the stereo is good for you. Just plug in the cig lighter and set the transmitter to an used portion of the fm band and the radio to the same frequency.
    https://www.amazon.com/Nulaxy-Bluet...gid=pla-873572225959&ref=&adgrpid=95587150004
  12. Oct 25, 2021 at 9:28 PM
    Epo3412
    Edward
    No interference? No static?
  13. Oct 26, 2021 at 3:10 AM
    tvpierce
    Maine
    +1
    I used one of these for years and it worked great. The phone connects to it automatically every time you start the truck -- just like a newer head unit.
    I found two drawbacks:
    1) The outgoing hands-free phone audio was less than ideal because the mic is on the unit, which is down by the floor.. I could hear just fine, but I sounded like crap to the person on the other end of the call.
    2) When I traveled out of my home area, it could be troublesome finding an open frequency that stayed clear. Honestly it wasn't that big of an inconvenience, but it did happen a few times.
  14. Oct 27, 2021 at 5:04 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    I went with the GTA carkit. Provides BT, USB out (for charging) and an AUX input. Plugs in the back of the OEM head unit and tucks nicely out of the way. Not one compliant for folks on the other end of the call.
    It's a bit pricey but is another option...
    shifty` likes this.
