USB interface
Discussion in 'Audio & Video' started by SuperSaiyan4GT, May 15, 2019.
  1. May 15, 2019 at 4:05 PM
    SuperSaiyan4GT
    SuperSaiyan4GT [OP] New Member
    Dustin
    2016 Toyota Tundra Blazing Blue Pearl V8 iForce
    No modifications done yet.
    Has anyone connected their stock usb module to their aftermarket headunit for the use of android auto or apple car play? I order a part to connect it but my phone keeps disconnecting.
    Pudge likes this.
  2. May 15, 2019 at 4:15 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    From what I understand, you can not use the stock usb port for android auto or apple CarPlay. I'm sure it could be done but youd pretty much have to remove the usb port parts and replace with a compatible usb. As it is right now, It will work as a usb input but you need to use the dedicated usb cord on the back of the head unit for android auto. I ran an extension on mine into my center console and plug my phone in to that.
    Toyotoholic likes this.
  3. May 15, 2019 at 4:19 PM
    SuperSaiyan4GT
    Dustin
    Yeah I had an extension run through the little spot next to the power outlet
  4. May 15, 2019 at 4:23 PM
    Navy Jumper
    Navy Jumper Airborne Paratrooper
    2023 TRD PRO
    I did in my 2015 Tacoma. Stock USB to adapter to Pioneer receiver USB, and used my phone via Android Auto with zero issues.
  5. May 15, 2019 at 4:26 PM
    SuperSaiyan4GT
    Dustin
    Anyway you can send me the link to the adapter so I can get an idea?
  6. May 15, 2019 at 4:32 PM
    Navy Jumper
    2023 TRD PRO
    VTYOTA likes this.
  7. May 15, 2019 at 4:36 PM
    SuperSaiyan4GT
    Dustin
  8. May 15, 2019 at 4:40 PM
    Navy Jumper
    2023 TRD PRO
  9. May 15, 2019 at 4:41 PM
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
  10. May 15, 2019 at 6:00 PM
    SuperSaiyan4GT
    Dustin
    Funny you say that. Before I saw this post I discovered I had an extension cable plugged in. After removing it and plugging the adapter into the headunit's usb it worked!
    Thanks everyone for your information. I hope this post helps someone else out
    Navy Jumper[QUOTED] likes this.
  11. May 16, 2019 at 7:59 AM
    tundraal
    tundraal New Member
    So you are using the factory USB that's located under the A/C controls? Does it work with Apple CarPlay? I am about to install a Kenwood in mine, but Crutchfield is telling me the factory USB won't work with CarPlay and I have to run a new USB.
  12. May 16, 2019 at 9:37 AM
    Pudge
    CT
    I had to run a usb extension for my kenwood as well. My kenwood had a usb cord from the back specifically for CarPlay/android auto. I got an adapter for my factory usb port that plugs into a different cord on the back of the kenwood and it works as a charger and usb input but not android auto. I got a cheap $8 4 foot extension usb and connected to the kenwood usb cord and ran it down into my center console. Works perfectly.
  13. May 21, 2019 at 3:09 PM
    SuperSaiyan4GT
    Dustin
    Sorry it took so long to get back to you. I am not sure about Carplay considering I use Android Auto. I would assume that it would work if you connect to the specific usb like Kenwood has
  14. May 21, 2019 at 5:11 PM
    tundraal
    tundraal New Member
    No worries. I installed the head unit and the Carplay works through the factory USB. Crutchfield doesn't know what they are talking about sometimes. All is good!
  15. Jun 14, 2020 at 4:08 AM
    Bloomjtundra
    Bloomjtundra New Member
    Josh
    2011 Tundra DC 4x4
    I have the brown connector to USB adapter cable, but can’t figure out how to connect it to the factory USB Port. Can anyone give me some advice on this?
