USB Charge dead with key off
Discussion in '2.5 Gen Tundras (2014-2021)' started by icodeintx, Jul 14, 2022.
  1. Jul 14, 2022 at 1:05 PM
    icodeintx
    icodeintx [OP] New Member
    Scott
    Palacios, Texas
    2021 Cement Gray Tundra SR5 CrewMax
    LED Headlights, LED Fog Lights, LED Interior lights
    It really chaps my rear that I cannot charge my devices unless the key is on. Does anyone know of an easy fix to keep my USB ports energized?
  2. Jul 14, 2022 at 1:31 PM
    Taco-Spike
    Two Trucks
    Could rewire them to a circuit that's always hot
    Use a Voltmeter to test which is hot with ignition off
    BravoDeltaRomeo and 1lowlife like this.
  3. Jul 15, 2022 at 11:26 AM
    icodeintx
    Scott
    Palacios, Texas
    I was hoping for a hidden switch, but I can do that too
    Taco-Spike[QUOTED] likes this.
  4. Jul 15, 2022 at 11:30 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    There's a relay in the engine bay box that you can remove and replace with a jumper wire. I've seen a writeup on it on here, should come up with a search and some digging.
  5. Jul 15, 2022 at 9:45 PM
    icodeintx
    Scott
    Palacios, Texas
  6. Jul 17, 2022 at 10:25 AM
    rodm1
    rodm1 New Member
    I ran a hot direct to the cigarette lighter in the storage compartment in the console then flipped the factory connector around for the ground. I can change back to factory in like 2 minutes if needed. Give use a review on that please.
  7. Jul 19, 2022 at 7:23 PM
    icodeintx
    Scott
    Palacios, Texas
    I got the part early and here is the result.
    I first ran a hot wire from the battery through the firewall under the dash down the console into the console storage. (drilled 1/4) hold in console storage to run the wires into the storage area. For a negative wire I stole it from the cigarette lighter which will never be used. I cut the positive off the cigarette lighter and taped it up so it doesn't touch anything.
    I used two parts.
    1. Six port fuse bus (not this exact one but one like it I found local)
    2. USB Fast Charger
    Excuse the dust mess I made during this work :)
    I like this option because it gives me 5 more ports if I want to do anything else.
    All said and done looks like this.
    The part fits perfect (if you order the right size). Note that there are two sizes and the 1.3 is the correct size.
    I have only one complaint and that is the USB charger light stays on all the time. Not just when something is plugged in. If this poses a problem then I'll install a little switch somewhere to turn this on and off.
    Hope this helps someone down the road. At the end of the day I now have fast charging without the key turned on. Some will ask why not wireless charging. That is because my phone rides in front of me on a mag mount. I don't want to pull it down to lay in the tray to charge.
    HulkSmurf14 likes this.
  8. Jul 19, 2022 at 8:57 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    You could probably take it apart and cut the power inside that goes to the LED ring.
  9. Jul 19, 2022 at 9:05 PM
    icodeintx
    Scott
    Palacios, Texas
    True but I think I found my answer. There is a blank port beside this charger and this would look perfect
  10. Jul 20, 2022 at 6:55 PM
    icodeintx
    Scott
    Palacios, Texas
  11. Jul 27, 2022 at 6:04 PM
    icodeintx
    Scott
    Palacios, Texas
    The results are in.
    New switch from eBay
    Relay has not come in so I just picked one up local for now.
    Quick Charge USB charger
    Here is what I have:
    1. Fuse Bus wired directly to my battery and installed in the console storage.
    2. USB charger which can be turned on and off by the current Passenger Eject button with truck on or off.
    3. Top portion of button lights up with button is pressed (on).
    4. Bottom portion of button lights up with dash lights.
    Now have have fast USB charging either driving or sitting parked and truck not running! Exactly what I wanted.
    I'm happy with the results.
    Blang805 likes this.
