USB Always On
Discussion in '2.5 Gen Tundras (2014-2021)' started by Buck4ua, Aug 22, 2016.
  1. Aug 22, 2016 at 5:13 PM
    Buck4ua
    Buck4ua [OP] New Member
    Yes I searched and no I didn't get any results bc usb is too short :)
    Any mod on keeping the USB always on to charge?
    Thanks, JB
  2. Aug 22, 2016 at 5:22 PM
    Leave the ingnition on Accessory. :rolleyes:
  3. Aug 22, 2016 at 7:11 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    I haven't seen one done but I know there's some wires that keep power to the radio to save presets and time so you could tap into that. DO NOT however tap into the air bag system, it stays on but not something you want (literally) blowing up in your face.
  4. Aug 22, 2016 at 9:16 PM
    bj46-taco-tundra
    bj46-taco-tundra New Member
    Mark
    Bj46 taco and now a tundra
    I installed a double USB charger from banggood (Chinese website) that installs perfectly into one of the blanks beside the 12v accessory plugs. I used a add-a-fuse and plugged it into the horn on the fuse box. Super simple and a flawless install. It's always on and never any issues of power draw from its little blue LED light (That is hidden by the cover when not in use).
    http://m.banggood.com/1224V-Dual-US...-Car-Charger-Adapter-For-TOYOTA-p-958489.html
  5. Aug 23, 2016 at 8:20 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    I converted one of my existing cigarette lighter outlets to be "always on". I cut the switched (+) wire at the back of the outlet and spliced in a wire I pulled direct from the battery. It is fused at the same amps as the socket is rated. If you do this be sure to insulate the old wire you cut as it will be energized when the ignition is turned on.
    Disclaimer: I am not a licensed electrician. I know just enough about auto electrical systems to burn my truck to the ground.
  6. Aug 23, 2016 at 11:22 AM
    Buck4ua
    Seems like some good options here. I'm going to play around with it this week. Thanks all!
    JB
  7. Aug 23, 2016 at 11:44 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I just bought a 2 USB port unit to replace one of my cigarette lighter plugs. I'm assuming the current cigarette plug is not always on? Good idea running a wire direct from the battery, what gauge wire and fuse size did you use? Is it wired in like this: [​IMG]
    Then you used the cigarette ground wire?
  8. Aug 23, 2016 at 2:33 PM
    Over the LINE
    New Orleans
    Yes, I used an inline fuse holder almost exactly like that. I am almost sure I pulled 16 ga. and also almost sure it is a 15amp. fuse to match the rating stamped on the cig. lighter door. I am sure that I matched whatever the outlet is rated for.
    The back of the socket has two wires coming out of it. One (+) and one (-). (I think the (+) is red but don't quote me) I cut the (+) wire with enough left to strip and use a butt connector to attach to my new always on (+) to the socket. I did not touch the (-) wire. I then taped up the old (+) so that it did not short when the ignition is turned on.
    P7040102.jpg If you zoom in you can see the back of the drivers side cig. lighter with the two wires sticking out.
  9. Aug 23, 2016 at 2:41 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Very cool, I think I'm going to install mine into the cigarette lighter in the center console and just use the current wires for now. Only time I'd use it is when I'm in the truck and driving, so shouldn't need constant power. I can always rewire it later, but that is for sure cool to know.
  10. Aug 23, 2016 at 2:43 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    This is what I got:
  11. Aug 23, 2016 at 6:08 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    It says that it replaces the cigarette lighter plug, but I'll see how well it does this weekend when I can install it.
  12. Aug 23, 2016 at 8:10 PM
    bj46-taco-tundra
    Mark
    Seriously boys, use an add a fuse and pop out that blank between your cigaret outlets. Wire this dual USB from Amazon to the add a fuse and the negative to ground and plug it into your horn fuse using the add a fuse.
    https://www.amazon.com/gp/aw/d/B014...toyota+usb&dpPl=1&dpID=41VP-ugErML&ref=plSrch
    15 min tops and it will always be on so you can charge your phone at the campsite without worrying about leaving your keys in the ignition.
  13. Aug 23, 2016 at 8:21 PM
    Over the LINE
    New Orleans
    I might have gone this way but I was already pulling wires from the battery and had the dash apart.
    I used the cig lighter not a USB because I can always use an adapter from cig to USB but not the other way around.
  14. Aug 24, 2016 at 2:30 PM
    bj46-taco-tundra
    Mark
    Dickey, rcinVegas, Bob and 2 others like this.
  15. Aug 24, 2016 at 2:32 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Nice! Wish I would have known about this before ordering the other part. O'well..
  16. Aug 24, 2016 at 3:12 PM
    PMG
    PMG New Member
    That looks great. Is there a write up on how to remove the dash/media pieces?
    PMG
  17. Aug 24, 2016 at 4:14 PM
    bj46-taco-tundra
    Mark
    I'd install that one in your armrest and still tap it into the horn. That way if there is an LED light that says on its hidden within your arm rest.
    Just my thoughts.
    Ps. Seriously how many 12v accessory plugs do you need in a truck, and yet no 120v. COME ON!
    Henry1jg and TTU19[QUOTED] like this.
  18. Aug 25, 2016 at 6:55 AM
    GayFish
    GayFish Member
    2016 Super White SR5 CM 5.7L 4X4
    https://www.amazon.com/dp/B01B73I5ZU?psc=1
    Not exactly what your talking about, but I leave this plugged in, in my console and it pretty much accomplishes the same thing. I attached it with some stick on Velcro to keep it neat, I get two usb plugs and a flashlight( not that I need another one of those counting the Maglite and the tac light on the glock, both of which are in the console as well).
  19. Aug 25, 2016 at 11:44 AM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    why did you install upside down?
    AJGallo41 and Dickey like this.
  20. Aug 25, 2016 at 11:48 AM
    bj46-taco-tundra
    Mark
    I wanted the cover to hang down to hide the blue LED light lol. I'd catch lol
  21. Aug 25, 2016 at 11:50 AM
    bj46-taco-tundra
    Mark
    Plus it matches the text on the top of the 12v power plug aswell duh
    Dickey likes this.
  22. Aug 25, 2016 at 11:51 AM
    RussellVaughan
    Houston
    lol both good reasons. looks great by the way!
  23. Aug 25, 2016 at 11:52 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I'm replacing one of the cigarette lighter plugs for mine, but not sure which one yet. The far left or right, or also thought about the one in the center console.
  24. Aug 25, 2016 at 11:57 AM
    bj46-taco-tundra
    Mark
    Center console is my vote
    #hideyourwires #ocdkeepingdashclutterfree
  25. Aug 29, 2016 at 7:14 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Thought I'd share here as well since the info is relevant. Very happy to report that I got the USB port installed. Hardest part was figuring out how to get the existing cigarette plug out.
    Took the negative off the battery, parking brake and popped the tab to put it in neutral. Unscrewed the shifter and popped off the center console.
    That exposed the cigarette lighter plug.
    Took a little finagling but got it out.
    Put the new one in and it fit like a champ. Tightned the nut down and good to go.
    Next was to wire it in. It came with wire taps but the original harness had 2 red and 2 black. Wasn't sure what to use and on examination I noticed the prongs at the end of the new wire looked exactly like that of the original plug. Looked the right size so I used a razor blade to trim the plastic around the prong.
    Plugged them into their proper side and fit perfect.
    Battery back on to test it and I'm high 5ing myself, It Worked!!!
    Plugged in the phone and it's charging!!
    Wrapped it in electrical tape to make sure they stayed plugged in, zip tied the excess wire and put the console back together.
  26. Aug 29, 2016 at 2:00 PM
    rmarch109
    rmarch109 New Member
    BOBBY
    2016 CREWMAX TUNDRA
    Where did you get this part and how much? I prefer the hidden wires in the middle console rather than an extra plug in the bottom of the dash personally.
    TTU19[QUOTED] likes this.
  27. Aug 29, 2016 at 2:07 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I got it from Sparks Parts http://www.sparksparts.com/
    I went on to get a direct link and I'm not finding it on there now. Maybe they are sold out? Humm...
    Balrz likes this.
  28. Aug 29, 2016 at 7:16 PM
    bj46-taco-tundra
    Mark
    Nice and clean. Did you find constant power off the fuse pannel or leave it at status quo. The other set of wires on that plug power the socket on the back of the concole. (Which should also be replaced with your fancy USB plug.). Nice write up man.
    TTU19 likes this.
  29. Aug 29, 2016 at 8:39 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I just left it as is and plugged direct into the existing wire harness. Maybe later I'll rewire it if I feel I need constant power, but for now its fine how it is. Thanks!
  30. Aug 29, 2016 at 8:51 PM
    bj46-taco-tundra
    Mark
