USA Spec TRD Pro
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by a_double, Aug 12, 2024.
  1. Aug 12, 2024 at 4:07 PM
    a_double
    a_double [OP] New Member
    Hi,
    The USA Spec TRD Pro doesn't come with parking sensors. I'm trying to source an OEM (L) rear bumper cap but the only options I come across is chrome/metal or plastic. All the plastic caps have the sensor hole.
    Is the plastic, non-sensor hole rear bumper cap available in OEM?
    TIA!
  2. Aug 12, 2024 at 5:37 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Just a heads up; this MOD is much more entailed than it would seem at face value... apparently, there's an issue w/the ECU and a few other things that would need to be changed out or updated to get this up and working. Just don't want to see you get into the weeds on this one, and it seems like that can happy real quick!
    If you have questions about the details of doing this, hit up @RainMan_PNW as he's explored it and is quite knowledgeable about the electrical/wiring end of things w/our rigs.
  3. Aug 12, 2024 at 5:55 PM
    a_double
    I’m not trying to add parking sensors. I’m trying to source an OEM plastic bumper cap that doesn’t have parking sensor holes.
  4. Aug 12, 2024 at 7:25 PM
    Tripleconpanna
    Sorry, my bad, I totally read that wrong...
    I shouldn't post until I've been awake for at least 30 minutes :anonymous:
    RobertD likes this.
  5. Aug 12, 2024 at 8:51 PM
    a_double
    No worries.
  6. Aug 12, 2024 at 9:16 PM
  7. Aug 12, 2024 at 9:20 PM
    RobertD
    Robert
    DFW, Texas
    https://www.sparksparts.com/oem-parts/toyota-end-cap-521560c030
    That says resin with no sensor hole. It's driver side but they also have passenger side available
    a_double[QUOTED][OP] likes this.
  8. Aug 13, 2024 at 11:16 AM
    a_double
    Thanks. I'm not sure that part doesn't have sensor holes. It seems to suggest "no sensor included." Not sure though. I've reached out to Sparks.
