Upper rear tail lights aren't working?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Berettafan, May 30, 2020.
  1. May 30, 2020 at 12:21 PM
    Berettafan
    Berettafan [OP] New Member
    2017 CM
    Pretty sure the top and bottom tail lights on my 17 are supposed to be on when driving right? Turn signals work, brake lights work but only the bottom is lit up when the headlights are on. I've checked every fuse that would seem linked to this as well as swapped some relays.
    Thoughts?
    Some add'l info: A boat trailer that has been causing my buddies dash lights to go out was recently towed with this truck. not certain if related. Also my front left blinker bulb had gone from dark amber to very light amber. Crazy sounding i know but i just replaced it with the second bulb in the pack and sure as heck the new bulb was darker.
  2. May 30, 2020 at 12:31 PM
    16 blue crewmax
    16 blue crewmax New Member
    Doug
    Richmond Virginia
    2016 Blazing blue pearl crewmax trd
    That is correct
    Bottom is brake and run
    Top is turn only
  3. May 30, 2020 at 12:35 PM
    Berettafan
    2017 CM
    oh so after 3 years with this truck i've failed to notice!
    Sheesh do i feel stupid! sure would look better with top/bottom on when running.
    thanks 16!!!
  4. May 30, 2020 at 12:59 PM
    16 blue crewmax
    Doug
    Richmond Virginia
    Yes I agree it would look better with both illuminated
