upgrading my zone 5” lift
Discussion in 'Suspension' started by glitch, Apr 2, 2022.
  1. Apr 2, 2022 at 3:43 PM
    glitch
    glitch [OP] New Member
    Jordan
    2014 Tundra
    7" BDS 35x12.50 on 20x12 -44 offset Chrome delete front grille, bumper caps, rear bumper caps and badges
    so i made a post the other day trying to get some information so i can figure out some ideas on how to add some more lift to my truck. i already have the zone 5” on my truck and just wondering if there’s anything else i can do to add another 2” to 3” or not? TIA
  2. Apr 2, 2022 at 4:25 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Anything higher and you’ll need a bracket lift so that your CV axles are not at risk of blowing up at such extreme angles.
  3. Apr 2, 2022 at 4:35 PM
    glitch
    Jordan
    2014 Tundra
    i was already considering a drop kit, but regardless of that, is there anything i can add to increase the lift of the suspension without a completely new kit?
  4. Apr 2, 2022 at 7:21 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Bigger tires but other than that no, not without damaging CV axles.
    As you lift the truck higher the distance between the front differential and the wheel hub increases placing the CV axle in a very steep angle and it would be very close to binding if not already. You’d probably drive off your driveway and snap a CV axle.
    You could lift the rear though and get some rake action.
  5. Apr 2, 2022 at 7:22 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Are you going for looks or planning to wheel the truck?
  6. Apr 3, 2022 at 12:29 PM
    glitch
    Jordan
    2014 Tundra
    so no aftermarket upper control arm or coach builder shims would help? i understand the distance i create between the dif/cv axles but i’m asking what suspension parts could i add to the front to add lift. i have a diff drop kit i can buy.
  7. Apr 16, 2022 at 7:13 AM
    glitch
    Jordan
    2014 Tundra
  8. Apr 16, 2022 at 7:51 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    You can try adding spacers. And/Or increase the amount of preload on your springs.
  9. Apr 16, 2022 at 8:05 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    What tires/wheels are you running?
  10. Apr 16, 2022 at 9:05 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    The zone 5” kit is a braket lift like the bds
  11. Apr 18, 2022 at 5:08 AM
    glitch
    Jordan
    2014 Tundra
    20x12 -44 offset and 35x12.50 tires but i planned on getting 37x12.50 or bigger depending on if/when i upgrade wheels as well.
  12. Apr 18, 2022 at 5:11 AM
    glitch
    Jordan
    2014 Tundra
    so i was thinking spacers for sure, and i’m guessing you have to take your shocks/struts to a specialty shop to do the preload on them?
  13. Feb 25, 2024 at 5:39 AM
    Trose808
    Trose808 New Member
    Just wondering if you ever upgraded your lift? I have the same lift kit since 2014. Looking to go a little higher and upgrade the suspension shocks.
  14. Feb 25, 2024 at 5:43 AM
    nags
    nags New Member
    2008 SC RCSB w/ all the goodies.
    I swapped out shackles to CB and used CB shims up front with my Zone and got about 1.5" more out of it with no issues.
    Coachbuilder1 likes this.
  15. Feb 25, 2024 at 5:45 AM
    Trose808
    Trose808 New Member
    1.5 more would be perfect. Were you able to do this at home? If so what tools were needed?
  16. Feb 25, 2024 at 5:46 AM
    nags
    nags New Member
    Shop did it in like an hour
  17. Feb 25, 2024 at 5:48 AM
    Trose808
    Trose808 New Member
    Appreciate the response! got any before and after pics?
    I’ll have to hit up my shop tomorrow
  18. Feb 25, 2024 at 5:53 AM
    Slap a body lift on it. Cheap and (kind of) easy. You get 2.5-3” of lift. I’m not a big fan myself of them, but if it’s lift you seek… can be added regardless of current suspension setup.
  19. Feb 25, 2024 at 6:22 AM
    Trose808
    Trose808 New Member
    I think I’ll stay away from body lifts. Heard bad things about them.
  20. Feb 25, 2024 at 7:23 AM
    Worse than adding spacers to a bracket lift for that extra 1" or two? They are all bad ideas to be honest. But if it's just the look, then they are all workable solutions.
  21. Feb 25, 2024 at 11:16 AM
    Trose808
    Trose808 New Member
    hahah good point. Appreciate the help!
