Upgrades for the Front Differential fill/drain bolt plugs?
Discussion in '2.5 Gen Tundras (2014-2021)' started by MedCityMoto, Nov 25, 2022.
  1. Nov 25, 2022 at 5:21 AM
    MedCityMoto
    MedCityMoto [OP] SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    I managed to get my fill bolt loose without much marring, but I can tell I'm going to end up mangling my drain plug when extracting it. Ordered a couple new OEM parts for cheap but wouldn't mind some nicer replacements.
    Normally I'd use GoldPlugs but they only offer a oil pan drain plug, and I'm going with Fumoto for that. Any other brands or links anyone else could share that they've used or liked?
  2. Nov 25, 2022 at 6:34 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    There’s an Aussie company KAON that sell replacement plugs that won’t strip but they are pricey
    texasrho83 likes this.
  3. Nov 25, 2022 at 7:37 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Are there fumoto valves available for the front diff drain threads?
    MedCityMoto[OP] and BTBAKER like this.
  4. Nov 25, 2022 at 7:58 AM
    AZBoatHauler
    So.Arizona
    I’ve done mine a couple times without issue - what makes you think it won’t come off clean? Hit it with a torch first if you’re worried.
  5. Nov 25, 2022 at 8:04 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I welded a socket onto the diff drain plug, I'd say that's about the best upgrade possible :D
  6. Nov 25, 2022 at 10:27 AM
    MedCityMoto
    My truck's a 2016, I've only owned it since August this year, so I'm unsure when the last change was, but good odds that it's been a few years. The hole's not stripped on the plug bolt, but it's marred, and I couldn't get it to turn even with a good breaker bar and using my leg laying on my back holding onto the tow hooks, lol. Have another OEM one on the way but wouldn't mind using something better for next time. I'm going straight to my impact and hammer next, see if I can't get it to come loose before I get desperate. My impact setup's removed some pretty gnarly retention screws from rusty rotors when doing brake changes, but I'd really rather avoid this struggle in the future.
  7. Nov 25, 2022 at 10:35 AM
    MedCityMoto
    With the magnet on the drain plug, I wouldn't go for a Fumoto on differentials myself.
  8. Nov 25, 2022 at 10:41 AM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
  9. Nov 25, 2022 at 11:05 AM
    MedCityMoto
  10. Nov 25, 2022 at 12:51 PM
    MadMaxCanon
    Good point didn't think about that.
  11. Nov 26, 2022 at 4:28 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I noticed that it important on the front differential fill plug that you get your allen wrench seated all the way.
  12. Nov 26, 2022 at 5:03 AM
    MedCityMoto
    Yeah I'm not a huge fan of the design in a location where small holes like that gather debris. Problem solved with replacement upgrades on the way, even cancelled my OEM replacement set order now that I've got better ones coming.
  13. Nov 26, 2022 at 7:35 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Isn’t there a much stouter Lexus plug that people put on their front diffs? I thought I remembered reading about it somewhere on here…
    Edited to quote:
    Yota303 likes this.
  14. Nov 26, 2022 at 7:36 AM
    MedCityMoto
    It's been linked in this thread!
    GODZILLA and Terndrerrr[QUOTED] like this.
  15. Nov 26, 2022 at 7:38 AM
    Terndrerrr
    Music City
    6UR-FE
    Just realized that’s what @TILLY posted. :thumbsup:
  16. Dec 8, 2022 at 12:47 PM
    MedCityMoto
    I just discovered I got over-eager and have two new fill plugs coming, the drain plug's been replaced now with the Lexus part and is great stuff. So if anyone else needs a new fill plug upgrade, let me know, got a spare here.
    RustyShackle323 likes this.
  17. Dec 8, 2022 at 12:56 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Ill be doing my fluids soon did you get the one linked above?
  18. Dec 8, 2022 at 3:41 PM
    MedCityMoto
    Sure did, two of the 90341-18060 fill plugs on the way.
  19. Dec 8, 2022 at 3:46 PM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Changing the fluids in mine in a couple weeks. Id take that extra one off your hands!
  20. Dec 8, 2022 at 3:47 PM
    MedCityMoto
    Alrighty, I'll drop you a note when I get them and we'll work it out
  21. Dec 13, 2022 at 9:43 PM
    MedCityMoto
    Sent you a message, received the second fill plug already. If you don't want it let me know and I'll see if anyone else is interested!
  22. Dec 14, 2022 at 6:26 AM
    MedCityMoto
    Confirmed I have one of these fill plugs available if anyone wants it, asking $15 via verified PayPal to get it to your door. My local Lexus/Toyota dealership wanted that much just in shipping to their local parts counter, and the cheapest on eBay is $34, but anyway let me know if you stumble across this thread and need it.
  23. Dec 14, 2022 at 2:20 PM
    gabex35
    gabex35 2020 Limited 4x4 with mods coming...
    San Diego
    2020 Cement Limited 4x4
    I’ll take it. PM Me your PayPal
  24. Dec 14, 2022 at 2:32 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I've done mine 3 times, with the right tool, there is no issue. Also, I torque them to spec.
  25. Dec 27, 2022 at 8:54 PM
    MedCityMoto
    Well well, I ended up with a second drain bolt too, anyone need a nice Kaon?
  26. Dec 27, 2022 at 8:55 PM
    MedCityMoto
  27. Mar 14, 2024 at 4:34 PM
    MedCityMoto
    FML. 1.5 years and 29k miles later, went to change front diff, and the Lexus part stripped like cheese. I don't weld so I'll have my local shop extract the motherf'r. Back to the Toyota 10mm hex, sigh. My deep 6-point impact 14mm fit nice and snug, but the part just wasn't up to the task at all.
    Fill plug came loose just as easily this time around too, lolz. Guess it's something to do with our salty roads around here.
    Henry1jg likes this.
  28. Mar 14, 2024 at 5:28 PM
    TILLY
    Massachusetts
    Well that sucks, you're the first one I've heard of having a problem with the Lexus plug. That plugs pretty beefy, did it round out?
  29. Mar 14, 2024 at 5:29 PM
    Terndrerrr
    Music City
    6UR-FE
    That sucks. I'd guess the salt is right.
    On my LX, I had to use my foot on a pry bar after heating the front diff drain plug to get it off. It hadn't ever been taken off in 149k miles. It wasn't until I put a camping torch on it for longer than I thought prudent that it finally broke loose. I was POSITIVE it was going to strip anyway.
    The torch worked on the flare nuts on the LX's brakes lines, too.
  30. Mar 14, 2024 at 6:22 PM
    MedCityMoto
    Very nearly, it clearly wasn't going to get any looser and my tools are just taking chunks of metal out of it. I'll snap a photo of it later.
    Best I can figure, I got sold a fake part, cause this is pretty bad, hot garbage. I heated a few cycles and can't get leverage underneath to smack it with a chisel so I'll let someone with a lift get at it.
    TILLY[QUOTED] likes this.
