Upgraded speaker rattle
Discussion in 'Audio & Video' started by Notmyfirst, Jun 4, 2024.
  1. Jun 4, 2024 at 10:14 AM
    Notmyfirst
    Notmyfirst [OP] New Member
    I replaced my door speakers. I have a rattle now for the life of me I can't find it. If I hold the door panel it stops. Let me know if anyone has the same issue or found a solution.
    Thanks
  2. Jun 4, 2024 at 10:30 AM
    Rockpig
    Rockpig You did what?
    08 Limited
    What did you replace them with, stock units or aftermarket? Sounds like you missed a clip or screw or something. Was there foam on the old speaker face that cushioned it against the door card?
  3. Jun 4, 2024 at 11:25 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Could be a number of things. Would consider starting with the connectors for the speaker wire and move to the connectors on the window switch panel next. Would also ensure screws to speakers/adapters also tightened
