Upgraded brakes
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dgoodin, Jul 21, 2023.
  1. Jul 21, 2023 at 7:51 AM
    Dgoodin
    Dgoodin [OP] New Member
    Derek
    2018 Tundra TRD 4x4
    Looking for an upgraded braking system for 18 Tundra. I looked into Wilwood and they recommended Fast Brakes. Does anyone have a package for caliper and rotors stainless lines? Somewhat reasonably priced?
  2. Jul 21, 2023 at 7:55 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    EBC dimpled/slotted rotors, Yellowstuff pads, Powerstop stainless lines - get the whole setup from BuyBrakes.com and use their 10% off code.
    Edit - oohh calipers. Mmm. Coffee hasn't kicked in yet. Powerstop has a kit on that same site, yes.
  3. Jul 21, 2023 at 8:18 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    What size wheel size are you planning to run?
    What sort of payload?
    Driving Type?
    Reason you feel that the OE braking system is lacking?
    Stoptech,
    Alcon,
    Willwood,
    Powerbrake,
    and whatever custom you are willing to properly retrofit.
  4. Jul 21, 2023 at 8:43 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
  5. Jul 21, 2023 at 9:25 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    https://alconkits.com/products/heav...-present-front-rear-complete-brake-kit-detail
    This should meet every part of your criteria, but they aren't cheap. I've had this full set on my fat pig of a 2018 CrewMax and have been very impressed with their performance. If you have the means, I highly recommend you picking one up...
  6. Aug 1, 2023 at 3:45 AM
    Dgoodin
    Derek
    2018 Tundra TRD 4x4
    Maybe you can tell me if you have 406.4mmx 30mm slotted and drilled front rotors for 18 Tundra 4x4?
  7. Aug 1, 2023 at 3:49 AM
    Dgoodin
    Derek
    2018 Tundra TRD 4x4
  8. Aug 1, 2023 at 4:11 AM
    Dgoodin
    Derek
    2018 Tundra TRD 4x4
    I received an email back from Wilwood however they do not have anything available, they did give me an email for Fast Brakes which can build and package 6-8 weeks out. Thank you Wilwood.
    Everything on the truck is stock. I purchased as the second owner and the truck looks and feels like the person before me took great care of her. However, I am a bit more aggressive. The "TRD" sticker on the side of the truck is a go-ahead and turn this thing up. LOL Right!? So it seems there is a kit that can be built that would include 16" or 406.4mm rotors. If I am looking for something a bit more quick guessing that I am looking at the 13.94" rotor. Correct? Meaning that the stock wheel will stay in place for a few. With prices,well...
    Anyway if any of you have some secret spot or site please advise. TIA
  9. Aug 1, 2023 at 4:13 AM
    Dgoodin
    Derek
    2018 Tundra TRD 4x4
    Thank you. I found a kit/package that will need to be built for a bit cheaper by about 2000.00 Have a great day
    HulkSmurf14 likes this.
  10. Aug 1, 2023 at 3:43 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    Nice! Please share details so others can compare and expand their options
    Gene_in_FL and HulkSmurf14 like this.
