Upgrade Your Truck with Premium Running Boards from RealTruck!
Discussion in 'Deals & Group Buys' started by RealTruck, Sep 6, 2023.
Thread Status:
Not open for further replies.
  1. Sep 6, 2023 at 12:57 PM
    RealTruck
    RealTruck [OP] New Member Vendor
    Looking to enhance your truck's style and functionality? We've got the perfect solution! This month we will be spotlighting the Go Rhino RB20 Slims, Go Rhino RB10s, Go Rhino Vertex V3 and the N-Fab RS steps!​
    The Go Rhino RB20 Slims are perfect if you are in the market for a new set of steps, but you aren't looking for anything too bulky! These boards feature the same raptor styling as the original RB20 Running Boards, but they are much slimmer at 5.5" the widest point vs 7.5" wide, like the full size boards. They are made from 16-gauge galvanized steel and come in your choice of textured black powder-coat or premium protective bedliner coating, both of which provide excellent protection against the elements!
    [​IMG][​IMG]
    The Go Rhino RB10 Running Boards feature a heavy-duty 16-gauge steel construction for unmatched strength, withstanding hundreds of pounds of downward force to support you and your passengers easily. The cab-length running boards also protect your vehicle's rocker panels, guarding against rock chips and minor impacts. Corrosion-resistant zinc plating encapsulates each running board, keeping rust at bay even if moisture bypasses the polyurethane coating.
    The Go Rhino Vertex V3 are aggressive looking and light-weight 5” oval steps. They are made from aluminum and finished with a textured black powder-coat to withstand the harsh environments met both on and off-road. They feature a very aggressive tire-tread polymer step-pad that provides excellent traction, so fear of slipping is never on your mind, no matter the weather condition.
    The N-Fab RS nerf steps are crafted from a sturdy steel tubing and protected by a dual layer powder-coating to form one stylish set of steps! The protective coating starts with an e-coat base-coating and then meticulously finished with a textured black powder-coating and fitted with plastic end caps to protect the steps from corrosion.With these steps, you and your passengers will be able to securely step into your truck with ease on the 4.75" wide die-punched step surface.The Nerf Step RS will add functionality to your ride as well as style with the rugged look of the textured hoop steps. N-Fab backs these steps with a limited lifetime warranty. ***MAIL-IN REBATE- Free Husky WeatherBeater Front Floor Liners with purchase! Offer ends 09/26/2023!***
    At RealTruck, our running boards are built to last and designed for easy installation, compatible with various truck makes and models. They offer:
    Style and functionality ✨
    Enhanced safety ️
    Easy installation ️​
    Ready to order or have questions? Simply shoot us a private message or email us at forums@realtruck.com, and our forum team will assist you promptly. Your truck will thank you for it!
    Upgrade your ride now! #RunningBoards #TruckUpgrades #PrivateMessageToOrder
Thread Status:
