Upgrade to bigger fuel tank
Discussion in '2.5 Gen Tundras (2014-2021)' started by dyvet2004, Jan 7, 2016.
  1. Jan 7, 2016 at 8:19 AM
    dyvet2004
    dyvet2004 [OP] New Member
    Maryland
    2016 Limited Tundra 5.7 Double Cab Trd Off Road Package
    Nfab nerf bars, Bilstein 5100's Front and Rear
    I have a 2015 sr5 double cab 6.5' bed 4.6 engine. I would like to upgrade to the bigger fuel tank. has anyone done this or have any insight on how to do this? Thanks
  2. Jan 7, 2016 at 8:52 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Too costly. Aftermarket is the path to take.
  3. Jan 7, 2016 at 8:53 AM
    dyvet2004
    Maryland
    Where could I start to look for a bigger aftermarket tank? any info will help thanks
  4. Jan 7, 2016 at 9:10 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  5. Jan 7, 2016 at 10:40 AM
    Airbagged
    Airbagged New Member
    2015 Toyota Tundra TRD off road DC
    Camburg UCA Fox 2.5 front Fox 2.0 rear Timbren bump stops 20" wheels Coachbuilders shackles Coachbuilders tie rod ends 46 gallon transfer flow tank Flush bed cover Billet grill LED light bar front Led reverse lights TRD sway bar rear TRD cold air intake Locker down consol safe Towing mirrors Fender flares Magnaflow exhaust TRD shift knob Magnum running boards Paracord wrapped grab handles And more
    Transfer Flo is the company to look up, the tank is 46 gallons, worth every penny I paid for it!!!
  6. Jan 7, 2016 at 10:41 AM
    dyvet2004
    Maryland
    ok great thank you
    Airbagged likes this.
  7. Jan 7, 2016 at 10:42 AM
    Airbagged
    The install is straight forward and bolts in the factory location using the factory sending unit, spring the extra cash and have them coat it for you with the bedliner material
  8. Jan 7, 2016 at 10:45 AM
    dyvet2004
    Maryland
    roger that.
  9. Feb 9, 2016 at 1:12 PM
    pdrhound
    pdrhound New Member
    T
    2015 sr5
    how easy was the install?
  10. Feb 9, 2016 at 1:21 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    The 3rd Gen Chilton Manuals aren't out yet but here's what I could pull from the 2013 manual.
  11. Feb 9, 2016 at 1:44 PM
    pdrhound
    pdrhound New Member
    T
    2015 sr5
    WQW! that is a thorough answer!. Was wondering more if bolts in place or needs modifications to lines or other stock pieces.
  12. Feb 9, 2016 at 1:50 PM
    Nor7
    You should also check out www.rockauto.com in addition to the earlier recommendations.
  13. Feb 9, 2016 at 7:34 PM
    tacouser
    tacouser New Member
    Chicago
    2015 SR5 Tundra Dbl Cab 4X4
    Bilstein 5100 rear, Klein train horns! Swing Case, Tekonsha P3 brake controller, Bed LED's, Weathertech window visors and floor mats,Retrofit Source Fog Lights, Bakflip cover, Ford Rapter hood leds, Hellwig rear sway bar
    Do you install it yourself? If yes was it pretty ez. Or did you have it installed? If yes do you mind saying what you were charged to install it?
  14. Nov 1, 2018 at 6:57 AM
    Bmxrider1331
    Bmxrider1331 New Member
    Brendan
    NEW JERSEY
    2013 tundra 4x4 4.6....
    3 inch toytec eibach kit on 35s
    Sorry to bump an old thread but I cant find a direct replacement for under the truck for my 2013 tundra 4.6?!
  15. Nov 1, 2018 at 8:42 AM
    Robster80
    Robster80 New Member
    Interested as well. How difficult was the installation ? could an idiot do it?
    Speydragon likes this.
  16. Apr 24, 2020 at 9:38 AM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Old thread resurrection.
    Interstate travel without fuel stops.
    It's happening. I'm excited.
    46gl Transferflo tank for the win!
    Free install with recalled fuel pump.:cool:
    Edit: Not free, paid for 1hr of service.
    They did try to charge me for the TSB reflash. I balked and they took it off. Turns out they wrote it up as warranty and not recall. Semantics. I'm used to playing this game so no foul. It's a dealership after all. I go there for the tech. He's a 2nd gen owner and skilled/certified.
    HulkSmurf14 and Cpl_Punishment like this.
  17. Apr 24, 2020 at 12:28 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    Oh yeah!
  18. Apr 24, 2020 at 1:32 PM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    Putting the factory 38 gallon tank in would be expensive if you bought a brand new tank. The 38 gallon equipped trucks have been around long enough that you can find them at the junk yard. I got a 38 gallon tank out of a truck that was totaled with only 700 miles on it for $250. I love the upgrade.
    trddriver and B.Ross like this.
