Upgrade suspension for towing.
Discussion in 'Suspension' started by Inkoosikas, Jul 28, 2019.
  1. Jul 28, 2019 at 6:59 AM
    Inkoosikas
    Inkoosikas [OP] New Member
    Alex
    2007 Blue Tundra SR5 TRD 4WD DC
    None
    Hello all!
    I am going to be towing a good bit with my 07 tundra that currently has stock suspension, wheels, tires and around 165k miles on it.
    I am at the point where I will need to get new tires in the next few months so I figured it would be a good time to upgrade suspension and level my truck so I can possibly fit slightly larger tires on it before buying new tires.
    I don’t know the exact weight of the trailers I will be pulling, but I do know they will be close to the limit of what you can tow with a Tundra.
    What I would like to know, is what I should go with to upgrade my suspension?
    I have heard a lot about Bilstein being the way to go, but not sure what setup I should go with?
    I am pretty sure that I will also want to put airbags on it, but I am also not sure about that.
    Like I said I also want to put on slightly larger tires, but nothing too extreme, just something to give it a slightly more aggressive look. Possibly 295/70R18?
    So basically I really have no clue what to do to my truck so I would love everyone’s input on it!
    Also as a side note, I don’t have a ton of money to dump into it, and I am planning on doing the suspension myself if it’s doable.
    Thanks!!
  2. Jul 28, 2019 at 7:28 AM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    I’m no expert, but a few thoughts, larger tires are going to change your final drive ratio giving you a little less towing power unless you also change the trucks rear gearing. If the tires are only a little taller it may be a mute point.
    I use air bags and I am very happy with them, allows handling the tongue weight without having heavy duty springs all the time if the towing is intermittent.
    ColoradoTJ likes this.
  3. Jul 28, 2019 at 7:54 AM
    Hbjeff likes this.
  4. Jul 28, 2019 at 8:37 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I’m with ColoradoTJ. You have a few very very opposite demands.
    You want to tow near the tundra’s max, but don’t want to spend a ton modding the truck.
    Big tires and towing means you need to regear. That’s expensive.
    If this were me, i would just get some nice tires in stock size, do the bilsteins on setting 1 and put the rest into the trailer.
  5. Jul 28, 2019 at 8:40 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Yup. Load distributing hitch (I think there may be a more proper technical name). :thumbsup:
  6. Jul 28, 2019 at 9:02 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I meant put the rest of the $$$ into buying the trailer :p
  7. Jul 28, 2019 at 10:52 AM
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    Depends on how much is left over. Might need the trailer to haul around the cash!
  8. Jul 28, 2019 at 11:16 AM
    Justin Case
    Justin Case New Member
    TX
    Good LRE tires. Not mud tires. Cooper AT3 XLT is what I would go for. 265-70-18. TRD sway bar. Airbags. Brake controller. BW GN hitch and GN trailer for 10K. Make sure to have a LRE spare tire and wheel for the truck. Put your truck spare with a floor jack in trailer.
  9. Jul 28, 2019 at 1:00 PM
    What kind of trailers? Flatbed car haulers, travel trailers, enclosed, boats??
    If I were in your shoes, stock size tires in a LT LR C (E's are easier to get, but are way overkill and add weight/rolling resistance), set of good shocks of your choice and factory setting, a good Load Distribution Hitch, brake controller, and see how things go.
  10. Jul 29, 2019 at 5:20 AM
    Inkoosikas
    Alex
    None
    Thank you everyone for your input! This is exactly why I come here. I am going to be pulling a 14” dump trailer quite a bit, I already have the trailer so no need to save money for that.
  11. Jul 29, 2019 at 8:28 AM
    Is this personal or in commerce?
    Reason I ask, if this is personal, you don’t fall under DOT rules in most cases (please check local and state laws).
    If you plan on doing this as a business (in commerce), you fall into DOT laws. Most 14’ dump trailers have 7K lb axles and are over your GTWR & GCVWR.
    Hbjeff and JohnLakeman like this.
  12. Jul 29, 2019 at 12:04 PM
    Inkoosikas
    Alex
    None
    It is for personal use.
  13. Jul 29, 2019 at 12:20 PM
    Mnorris1206
    08 tundra
    I run 35x12.5x18 tires on a 6" lift on my truck. I live in a very " flat " state Indiana but I have no issues pulling my camper. Close to 7500# loaded just this weekend . I was watching my gages and running at 50mph was in the 1500 to 2000 rpm range. Like others have said is it the " best no but these truck have the power to do so. If you just level and a little bigger I dont think you will have any issues. Post picks when it's done. :thumbsup:
  14. Jul 30, 2019 at 6:37 AM
    Inkoosikas
    Alex
    None
    So if I am going with the Bilstein shocks what is going to be the best setup for towing? 6112/5160 combo? Or is there something better? I really don’t have a clue about this so suggestions are very much appreciated!
