Upgrade suggestions
Discussion in '1st Gen Tundras (2000-2006)' started by SWVA_Tundra, Dec 26, 2016.
  1. Dec 26, 2016 at 7:18 AM
    SWVA_Tundra
    SWVA_Tundra [OP] New Member
    Otto
    2000 White Toyota Tundra 4X4 SR5
    Hello All,
    I am new to the forum and have a 2000 white Toyota Tundra SR5 with 200 K. The only issues I have ever had with the truck are the front brakes and the fame that was replaced during the recall. Again, the truck runs well but I know that I should start doing some upgrades and maintenance and was curious as to what you think I should start with first. Any suggestions are much appreciated and thanks in advance for your replies.
    Otto
  2. Dec 26, 2016 at 8:32 AM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Depending on what's been done as far as routine maintenance, i would say to change the timing belt and water pump. I've got 80 K miles on my 2001 and just did those items on mine. I need shocks all the way around now. I'll be doing that next month. Fix what's broken and do the specified maintenance and you should be good to go. Cheers.
    GNTundra likes this.
  3. Dec 27, 2016 at 3:26 PM
    Hossdawson
    Hossdawson New Member
    Hoss
    Harrisburg, PA
    2004 4wd DC
    Hi...Welcome from PA.
    I put Bilstein 5100's all the way around my 2004 Double Cab. It rides much better than with the oem shocks. Plus you can easily level the truck with the adjustable front shocks.
    Hoss
